Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
07-14 Solid AND POLY Motor Mounts
Old Jan 1, 2018 | 11:38 AM
Atomic Performance's Avatar
Former Vendor
Default 07-14 Solid AND POLY Motor Mounts
We are happy to release our Solid Motor Mounts for 07-14 GM trucks! These are solid motor mounts that fit 07-14 GM LS-equipped trucks including Silverado, Sierra, Tahoe, Yukon, Yukon XL, Suburban, Denali, and Escalade. They are a direct bolt up using factory hardware. Custom feedback is there is only a slight increase in vibration or noise and most say it is barely noticeable. These are laser cut 3/16″ steel fully MIG welded. All brackets will ship raw ready for your paint. They match factory measurements so the engine remains in the same location as stock.
The Poly version has the same mounting location but uses a larger bushing and 9/16" bolt to allow the engine and frame to rotate relative to each other reducing any potential vibration.
You can order through my website here: https://atomicfabandperformance.com/...m-fabrication/
Thanks and welcome to 2018!
Attached Thumbnails 07-14 Solid AND POLY Motor Mounts-20171124_120814.jpg   07-14 Solid AND POLY Motor Mounts-received_1609842585742054.jpeg   07-14 Solid AND POLY Motor Mounts-received_1630590333667279.jpeg
Old Jan 1, 2018 | 08:27 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Even the poly version should be way better than stock. Weve done some solid factory mounts and i dont like the vibrations that come though.
Old Jan 23, 2018 | 10:04 AM
Former Vendor
I just got more material in stock so I have plenty of mounts ready to ship!
Old Apr 23, 2018 | 01:23 PM
Former Vendor
Still have plenty of these available
Old Apr 28, 2018 | 04:56 PM
13chevy370's Avatar
Default poly mounts
Running any specials for Cinco de Mayo? Worth a shot
Old Apr 28, 2018 | 08:55 PM
Atomic's Avatar
I have a gauge for that
No specifically but there is a promo code for the entire store if you look around on this forum a bit
Old Apr 28, 2018 | 10:21 PM
13chevy370's Avatar
Just ordered! Thanks for the hint
Old Apr 29, 2018 | 01:20 PM
thewrx's Avatar
If we get bushings uninstalled so i can powder coat, will i need a press or just some elblow grease to get them in?
Old Apr 29, 2018 | 03:09 PM
SDjeff619's Avatar
You can pull the bushings out for paint or powder coat. I have the poly mounts on my 03 and I'm very happy with the almost zero engine movement and it still doesn't rattle the interior apart.
Old Apr 29, 2018 | 08:07 PM
Atomic's Avatar
The bushings go in easy, it's the center rod that's tight. I use a couple blocks of wood, some silicone spray, and a 5lb hammer to install them.
