Radical 102 Intake Manifold
Coming Soon From Peak Speed Shop!
102mm Radical Ported Intake Manifold for L92 owners
We have had repeated requests asking when the FAST 102 LSXrt truck intake manifold would be available for the newer GM trucks with rectangular ported heads. We haven't heard of any plans for FAST to put this into production. This has prompted us at Peak Speed Shop to create our own....
Porting intake manifolds and throttle bodies is Peak Speed Shop's primary business. We have perfected a method for completely opening up the plenum "tunnel" and removing additional barriers that restrict air flow in the 6.2L truck manifolds. This is in addition to porting the intake runners for better airflow. For the Radical 102, we also enlarge the throttle body opening on the intake manifold to accommodate a larger 102mm throttle body. We sell the Nick Williams 102mm drive by wire and FAST 102mm drive by cable throttle bodies for this application.
We will be ready to take orders very soon. You will be able to order from our inventory or can send your intake manifold in for conversion. Details coming soon!
Applications (6.2L L92 and L9H):
2007+ Cadillac Escalade
2009+ Chevrolet Tahoe
2007+ GMC Yukon Denali/Denali XL
2007+ GMC Sierra Denali
2008+ Hummer H2
2009+ Chevrolet Silverado 1500 Vortec Max
2009+ GMC Sierra 1500 Vortec Max
2008+ Hummer H2
Order your RADICAL 102 intake, now!
The best way to get your L92 to breathe!
(LS3 intake shown)
Packages start as low as $495!
Packages also available with Drive by Wire and Drive by Cable Nick Williams 102mm throttle bodies.
Order at our online store at: GM TRUCK - Radical 102 : Peak Speed Shop, Boosting Horsepower...Adding Style!
Or, call us at 719-651-1952.
(LS3 intake shown)
It should work with boost without any problems. We used to cut the top off to do the internal port work on these and then reattach it. Now, we can do all of the porting through the throttle body opening. Plus, we add supports on the inside of the L92 intake.
Just got this great note from a RADICAL 102 LS3 car customer!
“The new addition is great. I didn’t realize how choked up the motor was until the upgrade. I've gotten horse power gains of 23 with the porting and the new 102 throttle body. Thanks for all your help.”
Scott - Ponchapoula, LA – Radical 102, LS3
Car Owners, Order at: Radical 102 Porting - Car : Peak Speed Shop, Boosting Horsepower...Adding Style!
Truck Owners, Order at: GM TRUCK - Radical 102 : Peak Speed Shop, Boosting Horsepower...Adding Style!
