Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Working with AN fittings..... Got a question on wrenches...
Old Sep 26, 2008 | 03:46 PM
BlackGMC's Avatar
Resident Retard
Default Working with AN fittings..... Got a question on wrenches...
I am working with some AN fittings and I got a Summit AN wrench set, but the wrenches do not fit the NPT fittings (hose ends and NPT to AN adapters)... I was just wondering what everyone else used...
Thanks in advance....
Old Sep 26, 2008 | 04:43 PM
chevrolet all the way's Avatar
hammer and chisle is universal...
Old Sep 27, 2008 | 08:28 AM
sickREDsierra's Avatar
i have a full set of line wrenches i use for anything with tubing coming out of it like that, works very well.
then there is always a crescent
Old Sep 27, 2008 | 08:51 AM
silver-mod-o's Avatar
Hunt&Fisherator
I've always used just regular 'ole wrenches...just be careful with them not to ding up your fittings. Has always worked perfect for me
Old Sep 27, 2008 | 10:11 AM
Stoichiometric's Avatar
Open end wrenches work fine. Have you seen the fitting wrenches that are a 3/4 box end? Enough opening to get the wrench over the tube and you get a 3/4 grip on the nut. If those don't work resort to hammer, channel locks, chisel, impact then sawzall
Old Sep 27, 2008 | 10:38 AM
BlackGMC's Avatar
Resident Retard
I was able to find a set of NPT wrenches from Jegs, only $59 for 5 sizes... I ordered them last night should be here by Tuesday!
http://www.jegs.com/p/JEGS/754846/10002/-1
Old Sep 27, 2008 | 11:14 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
There are some line wrenches, but I've always used open-ended wrenches. Never had an issue with using 'em.
Old Sep 27, 2008 | 07:53 PM
built408's Avatar
I use just regular wrenches and never had a problem..
Old Sep 27, 2008 | 08:01 PM
parish8's Avatar
single digit dreamer
i dont really like the blue and red. i stick with the nickel coated stuff just to keep it all the same color and it doesn't seem to scratch up like the red and blues stuff.
Old Sep 27, 2008 | 08:31 PM
BlackGMC's Avatar
Resident Retard
Yeah I don't like the blue and red stuff either... I went with all black!
