Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
What should I do with the 418?
Old Jan 25, 2006 | 04:14 PM
  #21
get that bitch on the dyno. ****, did you even break it in before doing any full throttle runs on the street?
Old Jan 25, 2006 | 10:48 PM
  #22
gomer's Avatar
11 Second Club
I think you need to dyno/tune the ************ and then take it to the track to see where you are at on the whole deal.. then go from there. We've all followed this build over the past few months and we need some closure on the deal.
Old Jan 25, 2006 | 10:50 PM
  #23
gomer's Avatar
11 Second Club
Originally Posted by Tan327
There must be some way to get it to hook on the street. In Parish's videos I've never noticed him having too hard of a time hooking on the street, maybe I wasn't paying attention though?
That's what I was thinking.. 2bseen's truck runs 1.6x-1.7x 60's all day on 20 inch street tires.
Old Jan 25, 2006 | 11:29 PM
  #24
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Scott I in its current form I cant run it at the track the WOT 2-3 shift is not a good thing it slips BAD. Im going to get it tuned friday. I may get some 1/8th mile times but no 1/4 times unless the trans decides it will shift WOT 2-3. I know a solid roller cam is not "needed" but I WANT it. I dont like having the same **** as everyone Im not afraid of having to set the valve lash on it every 1K miles or whatever after it all breaks in good. I already have Jesel Shaft mount rockers with teh adjustable pushrod cups sitting in the tool box on my truck. I can spin the motor higher with a sloid roller valvetrain and wont ahve to worry about the lifters collapsing on me. I think the suspension mods that I am talking about will go a long way to making it hook better. Lowering it, cal-tracs and the shocks will make a big difference in how it hooks.
Old Jan 25, 2006 | 11:34 PM
  #25
1slow01Z71's Avatar
TX how do the toyos hook on the street when dry this truck wont be driven in the rain anymore.
Old Jan 26, 2006 | 12:33 AM
  #26
TXsilverado's Avatar
i serously think you need drag radials. i can light em up from a stop without any problem on the street and track. i dont understand how some guys say they can stall up to 1500(factory stall) and mash it to the floor on the launch and never lose traction with street tires. i had to stall to 800 and ***** foot it off the line to barely keep traction on the factory stall. you can drive my truck in march and decide for yourself if you dont decide by then. drag radials are your best bet IMO.
Old Jan 26, 2006 | 12:45 AM
  #27
1slow01Z71's Avatar
Yeah Im thinkin DRs are in order just dont like how short the ***** are. I am looking into finding some slicks for the rear that match my front tire hieght perfectly so I can heat the rear up hit the 4wd buttong and
Old Jan 26, 2006 | 12:49 AM
  #28
how far do you plan on lowering the truck?
Old Jan 26, 2006 | 01:02 AM
  #29
nitto 555 r 305/45-18 is almost 29" tall..28.78 to be exact. that wouldnt look horible on a 2/4 or 3/4 drop...
Old Jan 26, 2006 | 01:14 AM
  #30
1slow01Z71's Avatar
lift block removal, 2" drop shackle amybe jsut 1" front will be a while for the spindles but for now loosen the t-bars so 1" up front and 3 out back will look decent for now later spindles for 2" up front and lift the tbars back up and then 4 out back so yeah those would work well can you hook me up on those through your buddy
