Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
V6 -v8 Swap
Old Sep 5, 2006 | 08:11 PM
Default V6 -v8 Swap
How much is involved swapping out a V6 to a V8?
My truck is an 06 SWB truck. It is not extended cab either.
I would like to go ahead with a 6.0L, but should i get it from a truck or a car?
Also, who here in Houston, Tx could do the swap and how long would the turn around be and how much?
Would a new PCM be involved? or Fuel Pump? What about the tranny and rear end?
Any advice and/or suggestions are welcomed!
Old Sep 5, 2006 | 10:37 PM
Derek @ EDO's Avatar
FormerVendor
https://www.performancetrucks.net/fo...ht=NBS+v6+swap
Try searching, I myself as well as many others have given lots of info on these swaps
Old Sep 7, 2006 | 08:03 PM
This link has helped answer many of my questions. Thank you very much DLH2006!
I believe this link should be kept as a sticky so that many more can view it first without having to do a search.
Speaking of searches... i did that and this link did not appear.... what did appear were other ones that only discussed; and not into great detail; how others had already or were begining to swap their 6cyl for an 8cyl.
Although this link did not really relate the 6.0L; i am sure that pretty much everything would hold true for it as it relates to the 5.3L. In regards to the accessories and engine mounts, reflash of the pcm, but more than likely it would need an upgrade on the transmission and rear end?
Thanks again for the heads up....
Old Sep 7, 2006 | 09:03 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
I, as well as many, know it may seem like too much to search for, but there is a LOT of info regarding various types of swaps that you may get different info from. Just take the time, and search using key phrases like...
V6 to V8
If you'd like more details on something in particular, just ask. You WILL find the answer, and/or lots of opinions/suggestions on how to proceed. Not long til you'll be driving that project truck like .
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
superchomper2003
Aug 26, 2015 09:39 AM
iregret
Jul 27, 2015 10:32 PM
