Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
trouble code P0300
Old May 6, 2007 | 01:09 AM
GTOsRamairSilverado's Avatar
Default trouble code P0300
OK For the last two months or so my check engine light has been coming on and off. While the light was on i took it to autozone so that they could tell me what the problem was. They hooked up their little computer gagdet and they told me it was a multiple random misfire (P0300), i think that was the code. Any ways, the light will come on about every two or three weeks and stays on for a day or two then it turns off. Ive checked the spark plugs and the wires and they are fine. I checked them with a ohm meter. I have a wheatley tune for 93 octane, catless, and a bullet muffler, rebuilt tranny with a vig 3200. what could be my problem ??????
BTW i posted in this somewhere else but got no responses !
Old May 6, 2007 | 02:42 AM
PappyDan's Avatar
Tribe Shaman
did you get some bad gas?
Old May 6, 2007 | 12:20 PM
i doubt its the gas because ive filled it up about 8 time since the light started to come on and off
Old May 6, 2007 | 02:11 PM
Grumpy5.3's Avatar
did you have any lean codes to go with the 300???
Old May 6, 2007 | 04:23 PM
lean codes??? the guy at autozone just told me that it was a multiple random misfire and that was the only code showing.
Old May 6, 2007 | 08:29 PM
litreddevil's Avatar
Banned
do a compression test
Old May 6, 2007 | 08:36 PM
v8
17,16,15,14,13,12,11 Drvr
your misfire codes need to be set higher or your injectors need to be cleaned.
Old May 7, 2007 | 08:21 PM
why do you say my codes need to be set higher? and how would i go about doing that ?
Old May 7, 2007 | 09:20 PM
v8
your miss fire settings may need to be set higher.
Old May 7, 2007 | 09:37 PM
Banned
the only thing is if he has no cam that should not have to been done that is what causes miss fires
do you feel it miss fire
