Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
swapped out my dash lights last night
Old Dec 14, 2007 | 03:22 PM
  #21
nonnieselman's Avatar
With that PN.. it sounds like Superbrightleds.com
Old Dec 15, 2007 | 04:35 PM
  #22
PappyDan's Avatar
Tribe Shaman
just wondering what it would look like all red or green.
i have the super brite leds for when i build a sci-fi model.
blue, green, red, orange, i get the cheap off of e bay in
in sets of 50.
would like to do mine, lost a few lights off of the radio, think that would look
good in red, with cluster in blue and everything else in green.
one thing though for any one that does not know.
leds work one way, their not like a light blub.
one end is positive and the other is negative.
hook it up backwards and it will not light up.
Old Dec 16, 2007 | 08:29 PM
  #23
Tootall's Avatar
Originally Posted by Wheatley
Very nice
thanks
Originally Posted by ap2002
very nice matt!!
is yours next ?
Originally Posted by la Cuerva
Nice.... Where did you get the bulbs at?
superbright LEDs . . . hey bro, I'll send you a PM about it
I see you used the 6 bulb LEDs... i used the 4 Bulb and it came out ok... thinkin bout soildering the LED wires to the twistlocks... cause one of mine keeps blinking.....
the twist locks come apart that's how I did mine, and wedged them back in
yep!
in sets of 50.
it's really easy . . . the first one sucked, but it was easy after that. They have all kinds of colors to go with. They also have some that are directional also. YOU WILL NEED a small set of needle,long-nosed pliers for it, a regular sized ones won't cut it, they're too fat.
Old Dec 19, 2007 | 10:30 PM
  #24
Tootall's Avatar
ok, . . . I failed . . . . pulled out one orange LED and swapped it and the resistor . . . nothing . . . killed it.
Put the orginal resistor back in, and still nothing. So what am I missing. Anyone else here done this ?
Old Dec 19, 2007 | 11:57 PM
  #25
PappyDan's Avatar
Tribe Shaman
if you swaping one led for another, you should not have to use a resistor.
Old Dec 20, 2007 | 08:02 AM
  #26
leochevy2001's Avatar
one of mine started doing that too just this week.
i don't what the problem is though.
i was thinking that maybe the bulb was coming out or something.
Old Dec 20, 2007 | 08:19 AM
  #27
Tootall's Avatar
well that's what I thought . . . I was told to use a 680, and the one that I pulled out was a 1K.
Has anyone else done this?
Old Dec 23, 2007 | 08:49 PM
  #28
04BlackSilverado's Avatar
I have done quite a few LED swaps. I would need more info for exactally what your doing to help. But as far as the resistance, it really depends on Two things things:
1) The LED's ratings
The Resistance is dependant on its forward voltage rating, and the forward current rating (in milliamps). There are some calculators out there to find the correct resistance,
2) The Circuit your installing LED's into, and the # of LED's
If the circuit is Series or Parallel makes a huge difference. The Cluster in the 03+ is all parallel, which means source voltage is 14V at all Bulb locations so I need one resistor for each LED. Where as the AC Controller is three separate series bulb circuits. This means that the source is split three ways and three bulbs in each branch. I only have to use 1 resistor on the AC Controller because the LED's I use are rated for 4 Volts of forward voltage, so three bulbs takes 12 volts, but the 1 resistor is rated to take the additional couple volts from the trucks 14V Power.
If you were doing a direct swap from a LED to a LED the resistance difference would not be great but needs to be close. But if your going from a Lamp to a LED, then you may want to do some research on the curcuit and LED's.
Old Dec 25, 2007 | 06:38 AM
  #29
TexasCowboy26's Avatar
Registered User
i want to do red and it looks great man
Old Mar 31, 2008 | 11:26 PM
  #30
Tootall's Avatar
update: re-did the cargo/fog lamp switch
check it out !
