Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Something is definetly wrong
Old Nov 12, 2007 | 05:50 AM
DixieDevil's Avatar
Default Something is definetly wrong
I dont know what happened but all of a sudden last night my truck started to misfire very badly It'll chug out and feels like it wants to die for some reason... Happens when I try to get in the gas, I give it more than half throttle and the truck just bogs out... I get the flashing SES light so thats the only way I know there is a misfire This was just after I put gas in. I left the station and went to haul back to the house and it didnt want to Anybody have any ideas?
Old Nov 12, 2007 | 08:44 AM
TouchOfEvil04's Avatar
Check your cai. Make sure it's hooked up at all the connections. Mine came off before and did the same thing to me.
Old Nov 12, 2007 | 09:17 AM
Colby 04's Avatar
Well, since it started directly after filling up with gas - that's the first thing I would check.
Old Nov 12, 2007 | 10:33 AM
greyghost4x4's Avatar
Banging some gears
water in gas possibly
Old Nov 12, 2007 | 10:53 AM
DixieDevil's Avatar
Checked connections right after I posted this... Checked connections for my injectors, anything I could see, I wiggled and pushed to make sure it is tight...
I just dumped some Lucas treatment in it. Gettin ready to go back to work. Hopefully it'll run itself through... Sucks because I put half a tank in it
Old Nov 12, 2007 | 12:27 PM
DixieDevil's Avatar
ok, nothing is helping! It might even be getting worse When I get in the gas it really bogs down. Feels like someone dropped a ton of rock on the front end... I just hooked my amp and subs back up... could it have messed with the pcm or something? I am lost here... It just started out of nowhere
Old Nov 12, 2007 | 12:44 PM
ZZebes's Avatar
Siphon all that gas out and start there,
check plugs, wires, CAI, MAF
Unplug the battery for a half hour or so
Try the simple stuff first
Old Nov 12, 2007 | 01:00 PM
BLACKND's Avatar
I'b bet anything you've got a bad plug or wire. I had that happen to me twice with both my 04's and both times it was a bad wire.
Old Nov 12, 2007 | 01:41 PM
Colby 04's Avatar
If you got bad gas, additives may not help. You need to drain out the old and get some fresh gas in there. IMO, there's a strong possibility you got bad gas.
EDIT: A flashing SES light is usually an indicator of multiple cylinder misfire also...
Old Nov 12, 2007 | 06:04 PM
DixieDevil's Avatar
Went to Auto Zone and had them read my codes for me... Here they are... P0172 Bank 1 too rich
P0300 Random Misfires
P0101 MAF sensor condition
I checked the wires going to my MAF and as best as I can tell, it's fine. Tomorrow I'll take it out and make sure it's clean and everything... Is there any way to lean it out with out tuning? I am getting retuned by Rhyno79 next month, but he is in Arkansas.
