Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Short block assembly
Old Aug 19, 2007 | 04:19 PM
white1's Avatar
Default Short block assembly
Posting here too, cause I know some of you bastards only check the southern section
What kind of assembly lube do I need to use? Im realdy to start putting the pistons in, and realised I didnt think of this. Do I just need a thin coat of oil like doing a cam swap, or use the old school lube?
This isnt a new build, just a piston/rob/bearing swap
Old Aug 19, 2007 | 05:20 PM
Colby 04's Avatar
just use bacon grease
Old Aug 19, 2007 | 05:49 PM
slowec's Avatar
I use The wal-mart version of KY lube when I wanna kill a kitten.
Most builders use assembley lube on friction surfaces, but some use motor oil.
Old Aug 19, 2007 | 06:08 PM
FarmerBeau's Avatar
Sexy Party Mod
Id use assembly lube just to be safe. There is a key word "assembly."
FarmerBeau's Avatar
Sexy Party Mod
Do you know how/are you checking bearing clearances?
Old Aug 19, 2007 | 08:11 PM
white1's Avatar
I usually use plastigauge. But Im not. Im putting the bitch together, and driving it. If it knocks itll knock.
Old Aug 19, 2007 | 09:15 PM
quicksilverado's Avatar
If your gonna build it and run it without letting it sit for a while just use oil.
Old Aug 20, 2007 | 10:42 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Oil will be fine thats what Rex used to build my motor.
Texas5.3_1251
Mar 5, 2016 08:10 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
USMCvet0311
Sep 4, 2015 09:43 PM
