Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Rollpan Installation..
Old Nov 30, 2006 | 03:11 PM
blank260's Avatar
Default Rollpan Installation..
Just got my roll pan in the mail and wanted to see what shops any of you might reccomend that can adjust it and paint it, not weld in just bolt on. Im located in NW houston so it be best if anyone knows a shop in that area who can do it... Also, how much does it usually cost to have that kinda work done and how long?
Old Nov 30, 2006 | 03:26 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
looking at probably 200 bucks and just depends on the shops work load, it will only take two days to paint and cure though.
Old Nov 30, 2006 | 03:36 PM
BLACKND's Avatar
Just have someone paint it, Its not difficult at all to put it on. Helps to have a friend there to help you put it on, but I did mine on my old crew cab by myself. Just don't be afraid to use masking tape to tape off the edges of the bed and the pan, that way you don't scratch either one up doing the install.
I think the shop I used to paint mine was about 150 or so.
Old Nov 30, 2006 | 10:50 PM
blank260's Avatar
Doesn't the pan need to be adjusted to fit just right or can I just pretty much bolt it right up and it fit just like it supposed to?
Old Dec 1, 2006 | 07:29 AM
BLACKND's Avatar
It will most likely need to be adjusted a little bit here or there, but as long as you test fit it before hand, mask every painted area off that could possibly come in contact with each other, you should be fine. I actually also used a couple small strips of double sided tape to hold the pan in place at the top where the metal screws go into to I could line everything up and take my time and make sure it was right.
Really not all that difficult at all to do. Although some paint shops might not charge that much to do the paint and the install.
And you didn't say, but is it a Steel Roll pan like sir mikes? If so, you should just need about 6-8 sheet metal screws to mount to the top up by the bed floor and then the pan should have come with 2 kinda L-shaped brackets that mount to the frame and the screw to the inner lip of the bottom of the pan. At least thats how mine was.
Old Dec 1, 2006 | 10:03 AM
ColtSteele's Avatar
go out and test fit it before you paint it- you want to make sure you have the right one and test fitting it is about the only way to do it. a buddy of mine ordered one for his s10- sent it to paint- then tried to install it... woops- it was for a nissan or something but regardless he was stuck with it. He paid for the pan- painting and all and didn't have shi7 to put it on.
And like L3 said- tape up anything you don't want to take a chance at scratching.
Good Luck
Old Dec 1, 2006 | 12:20 PM
BLACKND's Avatar
Definitely test fit it before paint.
Old Dec 1, 2006 | 12:56 PM
ColtSteele's Avatar
yep- he learned his lesson the expensive way.
Old Dec 2, 2006 | 12:17 PM
blank260's Avatar
its a sir mikes
Old Dec 2, 2006 | 12:37 PM
beastmode's Avatar
Import Moderator
to bad you cant test fit em before you buy em lol, i woulda never bought mine
SS94S10
Jan 3, 2019 01:57 PM
Marine_SGT
Mar 1, 2006 08:31 AM
ap2002
Dec 8, 2005 07:26 PM
Powerhouse
Dec 2, 2005 08:48 PM
nick_4.8sierra
Jun 21, 2005 11:59 PM
