Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Not happy with my times on the bike
Old Oct 20, 2006 | 11:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Not happy with my times on the bike
Best I could muster was an 11.8 at 123 with a 2.4 60ft. It would either come up and do a wheelie or bog as soon as I let out on the clutch after babying it out of the hole. Raced a 100 shot Z06 and hung with him the whole way ended up being a .04 diff in times and he had a mph on me. I was shifting good just need to get my 60 down. Im not even sure what it "should" run with a good rider.
01 Honda F4i akrapovic full length exhaust, power commander evrything else stock.
I think its running a little rich down low too, it seems to bog a bit but not as bad since it has gotten cooler outside. Need to retune it but it will have to wait till the truck isup and running.
Allen Nelsons 5psi sts avalanche hit a 13.6 with just a 212/216 cam not bad for a 6000K truck, and everyone says the sts kits are just dyno queens
Old Oct 21, 2006 | 12:04 AM
Tan327's Avatar
Wait, you just went from talking about your bike to Allen Nelsons Avalanche. What does that have to do with anything?
Old Oct 21, 2006 | 12:22 AM
nonnieselman's Avatar
man you ran a 11.8 on a slighty modded F4i? IIRC they usually can run a low 11 with a good driver..
If you plan on drag racing it the right way, you better go ahead and order a few extra Clutchs..... Red line that motha and slip the clutch off the line hard... my cousin used to race a ZX9R, he said the best you can do is drive it with the clutch... im not dumb enough to try and lauch one, i just like cruising.
Old Oct 21, 2006 | 01:23 AM
Old Oct 21, 2006 | 06:00 AM
Applegarth's Avatar
The best way that I found to launch a 600 (04 R6), was to rev it up to around 7k and let the clutch out as fast as you can while rolling on the throttle. You should be full throttle by the first 60'. I usually get around 1.7 60'.
Once you strap the front end down you can go full throttle off the launch..
Old Oct 21, 2006 | 08:01 AM
1slow01Z71's Avatar
Allen was at the track with us, look where Im located
The problem was when I tried to launch it hard at ~8k and slip the clutch it would smoke it pretty good and the shifts the rest of the track would be "greasy". It has the stock clutch in it. Im not big into drag racing the bike since even if I fo set it up right it will still be slow. I use the truck for drag racing.
Old Oct 21, 2006 | 02:41 PM
Scrapin'4.8's Avatar
Practice practice practice, and tying the front end down. But yeah don't get too into racing the bikes and then wanna stretch it and stuff because it takes the fun out of riding. I sold my liter bike a couple months ago because it was way more than i needed, i'm looking into gettin a Vmax now.
Old Oct 21, 2006 | 03:05 PM
99Silverado5.3's Avatar
strap the front end down, and keep your weight in the front and you have to slip the clutch hard, so you probably need to get a racing clutch if you plan to keep on racing it.
Old Oct 21, 2006 | 03:11 PM
1slow01Z71's Avatar
With a better clutch Im sure I could get a MUCH better 60ft but like I said it is the stock clutch and it has been riden hard
Zizzle
Oct 19, 2017 08:44 PM
AHelm3
Apr 8, 2016 07:51 AM
AUTOT3K
Aug 26, 2015 12:36 PM
thewrx
Aug 12, 2015 08:28 PM
captrob62
Aug 3, 2015 08:44 PM
