Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Need a little help with engine, spun cam/main bearings.
Old Oct 19, 2007 | 12:51 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
First thing you need to do is take the belt off to make sure it isnt anything to do with any of the accessories then I would pull the front cover off and check the cam retainer plate. If all else fails just beat the **** out of it till it blows then you'll find out what it was
Old Oct 19, 2007 | 12:52 PM
Tootall's Avatar
thanks, but we're not doing the 3 motor mod.
Old Oct 19, 2007 | 12:57 PM
1slow01Z71's Avatar
Its fun though Im on the 6 motor mod now
Old Oct 19, 2007 | 01:17 PM
thunder550's Avatar
High on diesel fumes
Make sure you check the torque converter and flexplate bolts too, there's not a lot of clearance between them and the block.
Old Oct 19, 2007 | 01:26 PM
Tootall's Avatar
check them how/what for? . . . there was 1/2 to 1/4 gap between the TC, and the flex plate
Old Oct 19, 2007 | 02:40 PM
ridnlow's Avatar
My tc and flexplate bolts backed out on me after my motor swap and it didnt sound anything like that..
Old Oct 19, 2007 | 02:54 PM
Tootall's Avatar
well the flex plate bolts aren't going to back out . . . they have locktite, and 74ft lbs on them. The TC bolts are just heman`d on there.
I'm hoping that its something as simple as the starter, but that would be too good to be true.
Old Oct 19, 2007 | 03:12 PM
ridnlow's Avatar
Yea we forgot the locktite
Old Oct 19, 2007 | 03:22 PM
thunder550's Avatar
Ok, just an idea.
Old Oct 19, 2007 | 03:29 PM
Tootall's Avatar
Ok, just an idea.
thanks, I'm open to just about any ideas
