Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
my last step to 11's
Old Aug 24, 2008 | 08:26 PM
  #71
litreddevil's Avatar
Banned
Originally Posted by amadeospike
108.43 damnnnnn So when you commanded those shift points where was the truck actually shifting?
dude geoff at thunder took care of all thatthe truck had loads of dyno time on it trying all kinds of stuff.this is how i found out over 32* of timing just don't do no good.
Old Aug 25, 2008 | 09:54 PM
  #72
v8
17,16,15,14,13,12,11 Drvr
well the truck looks to be down untill late sept. or early oct. Once I get the heads back, I have to get tail piece on trans replaced do to it being cracked, going to paint calipers and rotors, fix different hoses, fix trans lines, No real rush right now since they put us on 7 days a week untill thanksgiving hahahaaaa,
haveing alot of work done around the house as well, building a new shop out back, new fence, tear down old fence and building, get dirt moved to back of yard 320' deep ahhaa, I have alot going on since this job was supposed to be 5/10's untill next year, damn planners&schedulers ahaaaaa, owell its just money and time, alittle more then the other LOL.
Old Aug 25, 2008 | 10:06 PM
  #73
07redchevy's Avatar
so your trying to run 11's on motor no spray??
Old Aug 25, 2008 | 10:21 PM
  #74
bluecajun5.3's Avatar
11 Second Truck Club
i have a tailshaft if you need one.
Old Aug 25, 2008 | 10:48 PM
  #75
StrokerAce03's Avatar
Are you going to keep the specs a secret or do you mind sharing the info on the heads? I'm wanting to get some more compression out of my 4.8. You, BlueCajun, 01Thunder, and litreddevil have been my inspiration since joining this forum of making a small motor quick N/A. I'm sticking with a 4.8 for now but I want to see what you're putting together
Old Aug 26, 2008 | 08:34 PM
  #76
v8
Correct
Will send you a PM shortly, and thanks
Not sure what there doing to them, well not all of the specs, milled, valve job, larger intake valve, PP, Dual springs.
Old Aug 27, 2008 | 03:55 PM
  #77
brave4it's Avatar
Can't wait to see it kevin, sounds like it's gonna be a BEAST!
Old Aug 27, 2008 | 06:11 PM
  #78
07redchevy's Avatar
whats your set up?
Old Aug 27, 2008 | 09:38 PM
  #79
v8
whats your set up?
full bolt-ons,cam,4.10's,stall converter, and now going to have better flowing heads.
Old Aug 29, 2008 | 02:38 PM
  #80
team39763's Avatar
Good luck with it bro, I hope you hit your #.
