Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
looks like i may have a problem here
Old Mar 4, 2006 | 08:05 PM
ranwalk's Avatar
Originally Posted by goshawk23
i'd hope there wasn't a hole in the piston unless you know something we dont.
No, I dont know anything new. going to go tommorow and get some new plugs. I hope its nothing, I really dont need this right now. After all the crap i've been through with this truck
Old Mar 4, 2006 | 08:17 PM
goshawk23's Avatar
Truck addict
i'll give you 5k cash right now.
Old Mar 5, 2006 | 12:11 AM
blacksheep's Avatar
Well at least I don't feel so bad, I blew up my trans on the way to the track today. Should have trailered it, but but today I decided to drive it. Atleast I beat the Mustang, maybe I shouldn't have left the light of the trans brake.
Old Mar 5, 2006 | 12:47 AM
Sport Side's Avatar
Wink
So, you bucked the hell out of that 'stang? ...Nice
Old Mar 5, 2006 | 12:49 AM
LMAO i would of love to see this!!!!
Old Mar 5, 2006 | 02:54 AM
$thatguy$'s Avatar
damn i would love to see somebody leave a red light off the trans brake.... LMFAO... but sorry to hear about that trans.... ranwalk you may have gotten lucky and the piece that broke or burnt off might have blown out the exhaust valve and didn't hurt anything
Old Mar 5, 2006 | 06:20 AM
goshawk23's Avatar
Truck addict
was that the 400? what are you gonna go back with? 4l80 or t350?
Old Mar 5, 2006 | 10:05 AM
BigKID's Avatar
Randy, looks like you just burnt the ground off. That is a common problem with FI. Get some new plugs and check your tune(afr/timing). Do you have a wide band in the truck?
Old Mar 5, 2006 | 11:42 AM
ranwalk's Avatar
Update---I changed the plugs this morning and fired it up. No abnormal sounds from the engine, sounds fine. I will not be celebrating too soon though. Time will tell, and I will be checking the plugs soon after I drive it a litte. The tr6's that were in it were the original ones I had in it when the engine was built. Only had 5300 miles on them, but they have been run on 2 different tunes, 2 different size Whipple pullies and I also drove around for about a week only making 2 pounds of boost running pig rich because I had a problem with the bypass valve not closing fully. did any of that cause this? with my luck, no it didnt. I have my fingers crossed that all is good now.
I dont have a wideband. I can probably check a few things at work with the tech2.
The tune was just checked a few weeks ago at Allans though. I guess these plugs could have allready been on thier last leg by then? Several of the other plugs looked like the ground had been pretty hot too,just didnt burn anything off of them.
Old Mar 5, 2006 | 11:50 AM
JimS's Avatar
Could you beg/borrow/steal/rent a scope to look in there? Maybe that head should come off or is there a way to reach in there through the plug hole to pull that scrap piece out? Running it sounds to me like a bad idea.
