Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
K&N & airbox mod =
Old Nov 4, 2006 | 12:52 PM
2k5Squirrel's Avatar
14 Second Truck Club
Default K&N & airbox mod =
4 tenths in the 1/4. i ran a 14.7@93 last night and the only change has been a drop in K&N and cut a hole in the bottom of the airbox.
Old Nov 4, 2006 | 12:53 PM
EXTREME's Avatar
DAMN, impressive!
Old Nov 4, 2006 | 12:55 PM
Originally Posted by EXTREME
DAMN, impressive!
i know it, thought i might get a tenth or two, but 4 tenths....
Old Nov 4, 2006 | 01:06 PM
bluecajun5.3's Avatar
11 Second Truck Club
great!
how was the weather from the last time?
Old Nov 4, 2006 | 01:19 PM
Derek @ EDO's Avatar
FormerVendor
im sure that the track condition, cooler weather and prep also had a factor in your change in time unless you did this mod last night at the track and made a run with the stock setup and then did your mod and ran again to compare times. Also check your 60ft etc. and compare to previous run because you may have hooked better on the second run which may have given you 2 tenths which means the mod may have only given you two as well. Regardless great job on the 4/10th knockoff!
Old Nov 4, 2006 | 01:37 PM
SlvrSierra4.8's Avatar
Congrats man...... How big a hole did you cut in the bottom? Did you cut through the plate too?
Old Nov 4, 2006 | 03:55 PM
BlackLM7's Avatar
Wow, are you sure the weather and track conditions were the same as the last time you ran? I may have to try the airbox mod now.
Old Nov 4, 2006 | 04:10 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Bout 10*s difference, on his previous best he pretty much dead hooked, this time it would have been worse with teh added power. His wife did manage a half track burnout though last time
Old Nov 5, 2006 | 03:24 AM
Wheatley's Avatar
Truck Sponsor
damn man,very nice.That thing is running very strong especially for what you have done.
Old Nov 5, 2006 | 04:45 PM
there's already a hole in the metal plate. i tried to match them up.
man, she scared the **** of me with that one lol
i think so myself, i really don't have that many mods. i think with a posi a 14.5 could be had.
