Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Just removed the throttle body........
Old Sep 25, 2007 | 03:02 PM
slowprocess's Avatar
Default Just removed the throttle body........
........for the first time in about 3 years. I can't believe how freakin nasty the inside of the intake is with buildup.....What do you guys use to clean it? Seafoam? I honestly can't believe how bad it is, and after seeing the inside of the intake, I had almost forgotten how nasty of a design it is. I'm glad I looked because the nos nozzle I was going to use for my first stage is too short to use in the egr hole. Looks like I'll have to use my old shark nozzle after all.
Old Sep 25, 2007 | 03:10 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Take it off and use non-chloronated brake cleaner. Time for a catch can.
Old Sep 25, 2007 | 03:23 PM
Good deal.......a catch can is definately on the list now. Now that I think about it, I don't think this intake has ever been cleaned....150,000 miles on it. I'm going to clean it as well as I can with it on, because its getting an intake upgrade real soon.
Old Sep 25, 2007 | 03:27 PM
BradS's Avatar
I just used carb cleaner that was ok for sensors (Berryman Chemtool) and a tooth brush
Worked great
Old Sep 25, 2007 | 03:59 PM
1slow01Z71's Avatar
If you are worried about the MAP sensor it just pops out, then you can spray to your hearts content. Hot water off your water heater will clean the intake well too then finish off with brake cleaner. I have used this method on my old 5.3 that had a bunch of gunk built up on it with good success.
Old Sep 25, 2007 | 05:07 PM
nightrunner's Avatar
Mr. Obvious
do not use carb cleaner!
use only throttle body cleaner. im not sure about brake cleaner, never used it.
Old Sep 25, 2007 | 05:13 PM
BradS's Avatar
Why not? --- I used it with no problems
Old Sep 25, 2007 | 05:35 PM
Mr. Obvious
https://www.performancetrucks.net/fo...d.php?t=398989
for some reason my pics arent working but ...
side i didnt use carb cleaner, only tb cleaner
side i used carb cleaner on part of it
the brownish area is where i used cabr cleaner, it takes off the teflon coating
Old Sep 25, 2007 | 06:00 PM
1slow01Z71's Avatar
He is cleaning his intake not his TB. Non-chloro brake cleaner wont do that to a TB either thats why I use it, not to mention it leaves NO residue.
Old Sep 25, 2007 | 06:13 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I use alcohol.....daily
