Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
guys i have a question about coils
Old Sep 1, 2008 | 09:21 AM
litreddevil's Avatar
Banned
Default guys i have a question about coils
I have heard different thinks about the 2 different coils.the round ones and the square ones.witch one is better.witch one do i want to use.
Old Sep 1, 2008 | 02:15 PM
Spoolin's Avatar
GFYS and STFU
Square, ftw!
Old Sep 1, 2008 | 06:56 PM
Banned
Originally Posted by Spoolin
Square, ftw!
can you tell me why they are better
Old Sep 2, 2008 | 10:02 AM
nonnieselman's Avatar
haha I'm not sure if he knows the difference between a square and a circle Randy..
If you have both sets. I'd try one then the other. but I believe there's not goin to be a difference..
Old Sep 2, 2008 | 04:09 PM
454SuperSport's Avatar
one of the LS1 performance books mentioned that the round coils had a bigger heat sink and worked better in high hp, high rpm setups
Old Sep 2, 2008 | 04:55 PM
Spoolin's Avatar
GFYS and STFU
Unfortunately Jonathan is 100% correct. I was just being retarded. I do know there is a difference between the 2005 coilpacks and the 2001's where the 01's are better but as far as the round ones...
Old Sep 2, 2008 | 05:03 PM
closet red neck's Avatar
I used the round ones in my pro street application.......most all of the ladder bar and four link cars use the round ones.
Tha square one you need to put under your seat to hold your big *** up......LOL!!!
Old Sep 2, 2008 | 06:47 PM
Banned
02SCSBZ71:E-fans,harness,ASP crank & alt,Volant ramair/k&n,UPD lid,Mac perf tube & elbow,Por & pol bbk 80mm TB/bypass,LS6 intake,48# injectors,Edelbrock 200's,Meziere elec. H2O pump,224/228,.581/.588,110ēsep,LS7 lifters,molly PR,LS2 chain,160 stat,Supermaxx header system,ORY,Corsa Sport,MSD 8.5,Built 60E,Hughes deep/fined trans pan,SFI fp,Fuddle 3400 verter w/ 2 coolers,Denny's alum ds w/billet trans & pinion yokes,Eaton LSD,T/A cover,Weld chyenne 6D's,BFG kdw's,Baer brakes,SST lines,stock tune.
all this and still slow you suck
Old Sep 2, 2008 | 06:49 PM
Banned
thanks that is what i am looking for so i need to use the squared ones cause it sure not going to have high hp maybe high rpm.
Old Sep 2, 2008 | 07:24 PM
fossil's Avatar
11 Second Club
I have tried all coils that I could and I cant tell a difference. Im a service mgr at a gm dealer and have had access to many different coils. Thats why a run the LS1 coils, they are the cheapest ones to buy. If I was fast, maybe it would make a difference?
