Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Ga f-body shootout Mar 19
Old Feb 18, 2006 | 07:10 PM
quicksilverado's Avatar
Default Ga f-body shootout Mar 19
There will be a ton of f-bodies at SDR on the 19. Would be nice to see a few more trucks also. I know SSlow4.8 and BadGMC will be there. Hopefully Yellowsierra will be there if he ever gets his truck back together. Even though it is a chevy event all makes are welcome to attend. Would be nice to see a few Hemis and Lightnings also. In between rounds TnT will be allowed. Good chance to get 15-20 passes if you desire. If you hot lap you can probably get 30+ runs in.
Old Feb 18, 2006 | 09:56 PM
Joey5.4L's Avatar
F body shoot out... Mmmmm all you can eat buffet!
Old Feb 19, 2006 | 12:32 PM
Bad_Apple's Avatar
I might try to make it up there by then I should have my new stall and FLT level 5 Tranny and new tune by then. Be a good time to run the Apple in the 1/4 see what it does.
Old Feb 19, 2006 | 02:31 PM
SSlow 4.8's Avatar
yep i'll def be there...
pending the tune or not
Old Feb 19, 2006 | 06:19 PM
StrokerAce03's Avatar
I'll be there as well. Hopefully my truck will be tuned by then as well.
Old Feb 19, 2006 | 09:31 PM
Ill most likely be there also to smoke Joe(SSlow 4.8) again and hopefully run a 13 sec pass. Seeing how at last years shootout i was cutting 2.06's with no rear brakes an 1000rpms of stall on shitty streettires, Im hoping ill cut some 1.xx's with my rear brakes now working and make some 13 sec pass's coasting the traps hahahaha but who knows maybe ill have found a driveshaft so i can stay in the gas the whole track!
Old Feb 19, 2006 | 09:36 PM
Get your drive shaft balanced. It only costs about 30 bucks.
Old Feb 19, 2006 | 11:41 PM
I'll see if I can make it down if I'm not working that weekend. Hopefully I can afford a tune before this time.
Old Feb 20, 2006 | 12:24 AM
You gonna be running this time David? I really want to see what your truck can do.
Old Feb 20, 2006 | 07:16 AM
I am planning on it. I got the stall back in. All I have to do now is get the I/C installed.
