Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Driveshaft
Old Sep 28, 2007 | 08:15 PM
GTOsRamairSilverado's Avatar
Default Driveshaft
anyone know where i can get my driveshaft aligned. i'm not sure if it need to be aligned but i recently lowered the truck and want to get it checked out. better safe than sorry!!!
Old Sep 28, 2007 | 08:19 PM
Derek @ EDO's Avatar
FormerVendor
you want to check your pinion angle!
Old Sep 28, 2007 | 08:20 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Are you getting a new vibration? How low and how lowered? It's the pinion agles that need to be corrected, simple shims are used.
Old Sep 28, 2007 | 08:27 PM
small amount of vibration and its lowerd 4/6 using spindles springs and flip kit
Old Sep 28, 2007 | 08:28 PM
i guess!!! im not sure what needs to be done if anything.
Old Sep 28, 2007 | 09:02 PM
shakesvho's Avatar
Old Sep 28, 2007 | 09:11 PM
where in the houston area can i get my pinion angle checked out and aligned?
Old Sep 28, 2007 | 10:56 PM
v8
17,16,15,14,13,12,11 Drvr
try houston drive train off of 45 north
Old Sep 29, 2007 | 02:59 AM
goshawk23's Avatar
Truck addict
it's a simple fix. you can do it yourself but v8 is correct. thats the place to take it too if you dont' want to do it yourself
Old Sep 29, 2007 | 03:00 AM
goshawk23's Avatar
Truck addict
your sig says you tuned your truck. i thought you were a allen nelson member
