Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Dielsel Mechanic
Old Jul 24, 2006 | 10:15 AM
Default Dielsel Mechanic
I have a 01 dodge cummins that I need help with. My dad was going down the street and the truck just turned off on him and now it wont start. it will turn over but just don't start and when it comes to diesel im clueless. So If anybody know a mechanic here in houston lmk
Old Jul 24, 2006 | 11:03 AM
goshawk23's Avatar
Truck addict
i seen a Ford do this and it ended up being the fuel pump had gone out.
Old Jul 24, 2006 | 07:44 PM
SSlow 4.8's Avatar
i understand that there are at least two relays for the glow plugs... check and see if they are both working...
in the older GM diesels.. there is a relay under the hood and a relay in the dashboard somewhere.. maybe search for glow plug wiring schematics and you can figure out where the relays are... you might as well start simple and maybe find out its just the glow plugs arent engaging correctly. If its not that, than idk, i've just started working on my diesel and im learning little by little.
Old Jul 24, 2006 | 09:28 PM
well most likely I'm just going to take it to someone that knows what they are doing I know it's going to b pricey but I have no other choice.
Old Jul 25, 2006 | 09:17 AM
HALL182's Avatar
It sounds to me like it could be an injector pump... If it is be prepared to spend some money!!!
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Cammed4ever
Sep 30, 2015 03:38 PM
old motorhead
Sep 29, 2015 08:22 PM
xxloudogxx
Sep 28, 2015 12:30 PM
Raiderjim
Sep 28, 2015 10:37 AM
