Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
This crank pulley is driving me crazy!!!!
Old May 7, 2007 | 05:03 PM
CHEVRACER83's Avatar
TAKE HOIST... REMOVE MOTOR..... PUT NEW MOTOR WITH NEW PULLEY IN..... PROBLEM SOLVED!!!
Old May 7, 2007 | 05:04 PM
Originally Posted by skinnyVHO
weld the arms of the puller to the pulley?
that would be interesting
Old May 7, 2007 | 05:05 PM
Bfh??
Old May 7, 2007 | 05:27 PM
Dock Rocker's Avatar
This will fix it!!
Old May 7, 2007 | 05:32 PM
FarmerBeau's Avatar
Sexy Party Mod
Yea, if you can weld worth a ****, do that. Itll help it stay on. Just make sure you let it cool first. I think thats a cast pulley so be careful.
Old May 7, 2007 | 07:08 PM
!thewhitestallion!'s Avatar
Jake the Snake
hey man i have a few pullers layin around the shop. i'll take a look at them and give u a call
Old May 7, 2007 | 07:36 PM
Phantom's Avatar
11 Second Club
hot crank pulleys are not good...ask me how i know
Old May 7, 2007 | 07:53 PM
$thatguy$'s Avatar
you can't weld on cast. plus if you get the pulley to hot it will seize to the crank then he's really fucked
Old May 7, 2007 | 08:14 PM
rdhemi345's Avatar
What about a slide hammer if you have room? You could wrap a chain around the pulley and use a decent size slide hammer.
FarmerBeau's Avatar
Sexy Party Mod
If you get it right you can. Ive done it before without a Nickel alloy but it isnt a very strong weld. All you are trying to do is to keeping the jaws of the puller from slipping off the tabs right? It should hold it on well enough for the jaws to catch.
Thats why i said let it cool because the metal will still be more maleable (sp?) and bend rather than hold up. Tack it on, tension it up and let it sit for an hour or so.
