Southern FL, GA, AL, LA, MS, TN, SC, NC,......AR
Colby04..
Old Mar 5, 2007 | 07:40 AM
v8
17,16,15,14,13,12,11 Drvr
I've never heard of breaking in gears haahaaha, pyle brothers allways told me go wot your not going to hurt it. but each his own.
Old Mar 5, 2007 | 07:09 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I left two posi marks when I pulled out of the shop after my gear swap and it ahs 45K on the gears with no problems...
Old Mar 5, 2007 | 07:35 PM
meatwad's Avatar
Fast lane preferred
My gear installer said get on it a bit, but 20-30 min drive time then let them cool completely. Heat/cool cycle supposedly allows the gear teeth harden to a final form = more strength. 500 mi total for break in. I followed this cause my installer warrantied his work if break-in procedure was followed.
Makes a little sense, but probably doesn't make that much difference. No problems after about 8-9000 mi.
Old Mar 5, 2007 | 08:49 PM
Rhino79's Avatar
9 Second Club
Colby, I can personally vouch for that transmission. That **** would bark the freakin tires when it hit 3rd! Worked like a charm, and like Cody said, he only had it in for about a month or two before we took that thing out.
Old Mar 5, 2007 | 09:57 PM
Colby 04's Avatar
I'm sure it's fine
I hope to have the gears broke-in tomorrow so I can beat on 'er a little
Old Mar 6, 2007 | 12:17 PM
TXsilverado's Avatar
Originally Posted by Colby 04
I'm sure it's fine
now can i call you out?
Old Mar 6, 2007 | 05:35 PM
Colby 04's Avatar
hell...if I say "no" then I can keep my victory
Old Mar 6, 2007 | 09:53 PM
if you say no, that means you forfit and i automatically get the victory
Old Mar 6, 2007 | 11:06 PM
Colby 04's Avatar
Cody, you're off the hook
I just got done testing the FLT tranny at WOT and it didn't flinch! The 1st-2nd is so much nicer than it was in my stock tranny too. I had the Transgo kit in mine, but I installed the wrong accumulator spring which made the 1st-2nd shift harsh. It would bark the tires at part throttle. The FLT shifts just right...I'm impressed
Colby 04's Avatar
Why you gotta be pickin' on a cam'd 6.0L?
