Regency RST Complete Write-Up Info
#472
formerly 2004RST (changed 11/19/2012)
hey guys that stuff you were talkin bout with the drill mod for the 5 spd. got a couple questions...is that for like from dead stop i rev through 1st and go to shift into 2nd and grind? cause i get that every once in awhile 2nd to 3rd isn't that bad for me cause i've gotten used to the shift length & whatnot
EDIT: i wanted to ask...anyone else pull up aside any mustangs? am i the only one that has no problem beating fox body 5-0's & new model GT's? i swear to god once i hit third i pull 2 lengths...i raced a foxbody for the first time today and he couldn't catch up...i dont get it...they've got roughly the same power with a lot less weight input is welcome
#473
#474
i havent bee to the track since the first year i had the truck. and back then i had the crappy gt2s on the truck with a open rear end and breakin it loose in 1st, 2nd and 3rd. with a final best time of 16.3, plus it was my first year with the truck so i wasnt the best at drivin the long throw. cant wait to go this year with the new set up
#476
1.5" front by way of spring and spindle
2" or 3" in the rear with shackle and hanger
you can call ground force and they will tell you. 724-430-2068 and just tell them you are lookin for info on your regency and they have all the info you need.
#477
the bumper itself, i believe it is. i believe they just formed the fiberglass airdam to fit it. atleast that is what they did on mine.
As far as the lowering, I just want to know what I need for a 4/6 drop? A 4/6 kit wont work now will it?
#478
if your airdam is like the one on booger's truck then that looks like the factory airdam. and your right the chevy airdam is different
for a 4/6 drop you will have to change the spindel up front and the spring if i remember correctly and in the back you have to c-notch and do a flip kit. other than that im not sure.
#479
hey RED04REGENCYRST have you upgraded your rearend? I have plans for a **** load of hp and trq and i don't think the stock rear will hold i was thinking of a 14 bolt 9.5 or a strange dana 60.
#480
hey i'm at around 41k miles anyone else have to replace shocks this soon? truck kinda jumps when i'm doin 60 nd hit small bumps...and if isn't there a way to get a couple inches drop in the rear by flipping the bracket or somethin? thanks guys
