Regency RST Complete Write-Up Info
#2111
Alright, after doing a lot of local searching, I found an LQ9 engine block that comes with valve covers, scorpion rocker arms, and the timing cover for only $200. I'm going to pick that up in a few weeks and start with my build.
Now any suggestions on what I should do to it?
#2112
Alright guys terrible news... My transmission has **** the bed. Was going 70mph down the highway in 5th and it just hardcore slammed out into neutral with one hell of a bang and when i put it back in 5th its justa scream'n. The scream is horrible in 1st-3rd, but 4th is totally fine.
If anyone has a T-56 rdy to sell, PLEASE LET ME KNOW ASAP!!!!!!! lol...
I hate my life right now...
#2113
Hey Red, when u did ur T56 swap did u have to buy anything else other than the transmission itself to put it on? And was it a T56 of an ls1?
#2114
t56.jpg picture by kren7604 - Photobucket
The tranny X-member bolted right up, but the driveshaft needed to be shortened 3" from 61" down to 58" and had to swap yolks.. had to do a little wiring to the tranny, and cross tune the pcm with the 02 T.A. tranny files
#2115
welp im going to order it tomorrow, screw it... Tremec T-56 Magnum will be getting ordered tomorrow... need to know a couple things...
Will the flywheel on my stock 5 speed manuel as well as the Master Slave be able to go on the T-56 or am i going to have to buy the one's specific to it?
#2116
#2117
I reused my flywheel of my stock 5 spd, all I had to do was spend $46 at local NAPA shop to get it turned, I also reused my factory master cylinder. My t-56 already had a slave cylinder on it, the connections are different into the tranny from 5-spd to 6-spd. (On that note I did have to customize my hydraulic line) truck hydraulic line is about 3' long f-body is about 1' 6" long so it wouldnt fit. I had both connectors cut off from the truck line and f-body line that went into tranny, and had the f-body end crimped on to the truck hydraulic line by local hydraulic/hose shop $35. Hose fits and and functions properly.
Sweet! Thanks for the info man! Ill let u know how mine goes. It should be shipped to me by next week, if not the beginning of the following...
And then i need to put all new exhaust on it and do the bodywork.
I might have this project done before summers over...
#2118
sounds good, I even got the RST boot to cover the original hole plus what I had to cut, im still workin on my shifter stuff to reuse the rst shifter as well.. got a bolt that fits the threads but gota figure out the angle to weld to the bracket to go to the t-56 shift linkage.. Im also still in the process of getting everything back together, cant wait to finally drive her around!! hopefully a couple weeks an ill have her all done! Its hard to get stuff done when u work on the road..
#2120
Welp, Christmas came early
Finally things are looking up!!
http://i1240.photobucket.com/albums/...ST/Headers.jpg
http://i1240.photobucket.com/albums/...RST/Wheels.jpg
http://i1240.photobucket.com/albums/...rontBumper.jpg
http://i1240.photobucket.com/albums/...ST/Exhaust.jpg
