Questions For SS owners
I have just purchased a used SS 04 and I want to lower, now here is the tricky part, how low can I go if I out 22" rims on it? I have heard several different this bit my goal is to go as low as I can before I have to start cutting. Can I get a little help on this!!!!
You won't need to cut anything for just 22s. Do a spindle and keys drop up front the a shackle & hanger drop out back. Or you can go with the Belltech drop leafs instead for a near 4" rear drop. 22s will fit just fine, but you'll need to switch to drop shocks.
I've got a 2/3 belltech drop.. which actually turned out to be more like a 3/4 after I adjusted the torsion keys, and the rear saged a bit. I've got 20" with 50 series tires and I already consider it to be "to close for comfort"
I would highly reconsider going -4 with 22" rims JMO
SWINGRRRR
Sep 3, 2015 07:49 PM
