Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Dyno Pulls
Old Apr 28, 2010 | 03:53 PM
06BLKDENALI's Avatar
Default Dyno Pulls
Has anyone done a dyno pull with their awd trucks on a rear wheel only dyno? If so, how did you do it? The only shop in town that is capable does not have an AWD dyno.
Old Apr 28, 2010 | 08:01 PM
CHILLLLLL's Avatar
formerly Stroked-DSM (11/24/2010)
just jack the front of the truck up and put it on jackstands...
...NOT! I just made my car RWD when I couldn't get access to an AWD dyno
Old May 1, 2010 | 06:39 AM
jadaven's Avatar
Remove front drive shaft?
Old May 1, 2010 | 09:43 PM
chpspecial's Avatar
Yes you can dyno the truck with the front drive shaft pulled out, just do not drive the truck with out it, and DO NOT have the rear tires at full stop while the trans is in gear. If you do you will hear the viscous coupler do funny things. I suggest that you put the trans in neutral when coming to a stop from a dyno pull. Many SSS owners have done this with out problems. The only ones that have had problems are the ones that pull the front driveshaft to go out and do burnouts and drive on the street. they usually end up needing a new TC
Old May 1, 2010 | 09:50 PM
Thanks for the input guys, I am was not sure if it was safe to pull the driveline and run.
Old May 13, 2010 | 08:12 AM
RSTinOKC's Avatar
Probably a silly question here, but rwhp would be higher than awhp would it not?
If so, what would be the point of rear wheel dynoing, even for tuning?
Oobray
Jun 13, 2022 03:38 AM
bighouse
Sep 27, 2015 12:37 AM
wrb002
Aug 25, 2015 03:56 PM
dselby25
Aug 24, 2015 07:26 PM
cammed06
Jul 24, 2015 12:09 PM
