Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
12 seconds
Old 07-29-2009, 10:19 AM
05RST2NV's Avatar
12 sec is nothing with a LS1 based engine.. Your stock 6.0 with bolt ons, converter, gears and spray will get you there easily.
Old 08-02-2009, 06:21 AM
DMF
DMF's Avatar
your planning on getting a built tranny right?.....There goes a chunk of the 12k haha
Old 08-02-2009, 11:09 AM
05RST2NV's Avatar
Mine wasnt built.. 3200 vig, Servo and shift kit thats it.
Old 08-02-2009, 05:24 PM
Fireman31's Avatar
Originally Posted by sschevy03
i have 12 thousand to spend and can do most of the work my self i would like to put a kenne bell super charger but i dont think just a supercharger would put me in 12s
Good luck finding a Kenne Bell twin screw for these trucks, AFAIK that kit was discontinued, unless you find a used one. If you want a 12 second 1/4, here is what you need...
CAI
Cat-back
LT Headers
Shift kit
Servos
160* T-stat
Plugs/Wires
TruCool Max trans cooler
Custom Tuning
and.....
MP112/122H Magnacharger w/3.0 pulley
2600-2800 stall TC
or.....
125-150 shot N20
3000-3200 stall TC
Either one of those combos whould get you well into the 12's.....keep in mind that you will need to address the brakes too, since the stock brakes are not even sufficient for an AWD SS in stock form.....
Old 08-02-2009, 06:35 PM
brobradh77's Avatar
Brakes..you have a ton of track left to slow down after your run so you dont need brakes....LOL
Dans combos is what most use to get into the 12's.
Old 08-02-2009, 07:03 PM
616 of 933's Avatar
Add a set of efans to the list above. There is a guy in WI with a cam (dont no specs) stall, elec water pump, head work and tune maybe alittle more not sure but he is in the 12's
Old 08-16-2009, 04:10 PM
11 Second Club
Z28RPM's Avatar
I went with a 6.2L Aluminam block, Cam, ARP Bolt and 200 shot 11.724 @ 117.09. Got about 7 K in it. The weight is the big killer in these. The same setup in a car. Wow, I'll bet mid 10'S. My truck weighs 6000 LBS. with me.
Old 08-16-2009, 05:23 PM
Michael Halo's Avatar
4 folwmasters should do it with crome gas cap door....
Old 08-16-2009, 05:25 PM
Wearin' da big hat
00ChevyScott's Avatar
a $12,000 chrome gas cap door would be sick
Old 08-24-2009, 09:59 PM
formerly Stroked-DSM (11/24/2010)
CHILLLLLL's Avatar
Spend $500 on a nitrous kit and spray the **** out of it. Do a wet 150 shot and a stall. That should get you pretty close to where you wanna be.
Quick Reply: 12 seconds
