Silverado SS, Joe Gibbs Editions, SSR Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
03 SSS Electric Fan Install Problem
Old Aug 23, 2006 | 06:17 PM
Registered User
Unhappy 03 SSS Electric Fan Install Problem
Got the flex-a-lites, a nelson wiring harness. Installed everything exactly as said, tuned with HPTuners to get the fans to come on and everything.
Now the problem, I got everything else worked out but this. One fan comes on when the AC comes on, runs fine with no problems at all. Now I have the fans come on at 160, once they come on the relay starts clicking on and off really fast and wont stop, the fans are on but they are also pulsating with the relay coming on and off. I have NO idea why its doing this and need help. I went back, double checked EVERYTHING and even switched the relays but NOTHING. It wont stop!!
Please help!!
Old Aug 23, 2006 | 06:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
ON at 190
Off at 185
you want your On temp higher than your off, I have a feeling it is not. been there done that
Old Aug 23, 2006 | 06:26 PM
Registered User
You sir are a genius, and yes I am an idiot.. Problem fixed!!
Old Aug 23, 2006 | 06:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
I am an idiot, you are just learning. Glad it worked out.
Old Aug 23, 2006 | 06:55 PM
tell us more about your flex light fan install. When I was tuning the truck yesterday with Brian from RPM I noticed that the fan variables were temperature set and % of total capacity set. Can you give a list of parts used and some install tid bits? I will write up an article on it and credit you on my site.
Old Aug 25, 2006 | 09:01 AM
mwalls54's Avatar
Need More N2O Mod
Originally Posted by BlownChevy
I am an idiot.
finally you admit it
Old Aug 25, 2006 | 04:02 PM
fastac4's Avatar
"tell us more about your flex light fan install. When I was tuning the truck yesterday with Brian from RPM I noticed that the fan variables were temperature set and % of total capacity set. Can you give a list of parts used and some install tid bits? I will write up an article on it and credit you on my site.
08-23-2006 06:28 PM "
The full size chevy is different than the SS ECM i believe.
Am I right here?
Old Aug 25, 2006 | 04:06 PM
Nick™'s Avatar
Am I right here?
nope, totally wrong. the SSS has an identical computer. The Flex-a-Lite kit however, is what is allowing the percent differences, that's all in the VSC and has nothing to do with the actual tune.
Old Aug 27, 2006 | 02:05 PM
fastac4's Avatar
Nope ,your totally wrong.
2003 Gm did not have CAN bus in 2003.
I found this info on Gm own website.
Old Aug 27, 2006 | 05:58 PM
BlownChevy's Avatar
blownerator
25 Year Member
You are correct, however all the way to 2006 the truck pcms are the same, almost.....some have different operation systems.....but they are still Delphi.
The trucks will be can bus in 07.
5.3Okasai
Mar 9, 2022 01:07 PM
Bluchevypick
Aug 18, 2015 09:11 AM
mr03silverado
Aug 13, 2015 11:40 AM
Ketis
Jul 23, 2015 12:37 PM
