Turbo crossover and down/up pipe (through hood) for Trick turbo T6 manifold
I bought the complete hot side setup with the intention of just using the manifold and crossover. But it ended up that Rick would have had to get creative fabricating a 3.5" DP to use with the crossover so I just had him use the manifold and make me a new crossover and downpipe. The reason he would have needed to get creative is the crossover was closer to the frame rail than his standard crossover which reduced clearance for the downpipe. This kit was run on an 04'.
So with the above said, I would suggest to the buyer to stay the course it was intended for and cut a hole in your hood to not worry about needing a downpipe.
This is for a pretty serious setup as the turbo was a GT5588. The pipe is 5" in diameter and is setup for a Turbosmart 66mm gate on the downpipe. I would suggest sticking with that gate unless you feel like cutting the flange off for the gate of your choice as I know a Tial V60 does not fit the Turbosmart flange. The entire setup is made from 304SS along with Trick flanges on the crossover and as you can see very well fabricated. So save yourself a good amount of money and or time if fabricating yourself by just picking up a Trick cast T6 manifold while finishing it off with this setup.
Selling for $225 shipped
Some pics below of as it's mounted on the truck, crossover clearance on the 4L80, and as it sits now.
Does the cross over hang below the frame rails? Will trans/converter cover fit or not? I need to modify what I got or find something since my truck is bagged and I need the crossover to tuck up as close as possible to transmission.
