I am selling the hot and cold pipes from my KB turbo kit. They have around 2000 miles on them. No issues whatsoever. I put the truck back to stock and these have been taking up space in the garage.
Hot pipes:
Built for Turbonetics T4 turbo (will fit others)
Stainless steel
3.5" downpipe
T4 turbo flange, 3" v-band into the downpipe
WG vents back into downpipe
JGS 50mm WG
Wrapped in fiberglass and coated in black silicone paint
Comes with all v-band clamps SOLD
Cold pipes:
2.5" into intercooler, 3" after intercooler
Low-mount intercooler w/ mounting hardware
Designed for E-fans and MAF-less, could be modified to include the MAF sensor
Modified to fit a stainless coupler with 3 1/8" NPT bungs for meth injection
RPS 50mm BOV, black
Pipes have been painted black but have some chipping from install and removal
Massive 4" intake tube and K&N filter
Comes with all couplers and clamps
Comes with custom brackets I made to secure the bottom of the intercooler to the factory splash guard bolts SOLD
Other miscellaneous parts:
Turbo oil feel line, -3AN PTFE lined stainless steel braided. Comes with drilled/tapped oil feed adapter that goes above the oil filter. Has a -3AN hose end at the turbo. Will come with a 1/8" NPT female T4 oil feed adapter, you'll need a male 1/8" NPT to male -3AN fitting, very common: SOLD
Turbo oil drain line, -10 AN stainless steel braided with -10AN female hose ends. Long enough to reach the oil pan right above the oil level sensor: SOLD
Methanol injection pump from Devils Own. About 9 gallons of 50/50 water/meth mix ran through it, 1/4" female NPT fittings: $75 shipped
Autometer 100psi fuel pressure sending unit with connector: $65 shipped
ARP head studs, 234-4110, long and short stud version, used for about 5k miles. Comes with two extra large nuts and washers: SOLD
Please PM me with any questions.
These pics are from KB and show the routing of the cold pipes:
How did u get that k&n adapter to work like that. I thought they originally bolted to the maf. Did u slip an exhaust pipe into it? I have an old one laying around just like it.
