KB Turbo Kit Hot and Cold Pipes
Old Jan 21, 2016 | 02:26 PM
Ferocity02's Avatar
Default KB Turbo Kit Hot and Cold Pipes
I am selling the hot and cold pipes from my KB turbo kit. They have around 2000 miles on them. No issues whatsoever. I put the truck back to stock and these have been taking up space in the garage.
Hot pipes:
Built for Turbonetics T4 turbo (will fit others)
Stainless steel
3.5" downpipe
T4 turbo flange, 3" v-band into the downpipe
WG vents back into downpipe
JGS 50mm WG
Wrapped in fiberglass and coated in black silicone paint
Comes with all v-band clamps
SOLD
Cold pipes:
2.5" into intercooler, 3" after intercooler
Low-mount intercooler w/ mounting hardware
Designed for E-fans and MAF-less, could be modified to include the MAF sensor
Modified to fit a stainless coupler with 3 1/8" NPT bungs for meth injection
RPS 50mm BOV, black
Pipes have been painted black but have some chipping from install and removal
Massive 4" intake tube and K&N filter
Comes with all couplers and clamps
Comes with custom brackets I made to secure the bottom of the intercooler to the factory splash guard bolts
SOLD
Other miscellaneous parts:
Turbo oil feel line, -3AN PTFE lined stainless steel braided. Comes with drilled/tapped oil feed adapter that goes above the oil filter. Has a -3AN hose end at the turbo. Will come with a 1/8" NPT female T4 oil feed adapter, you'll need a male 1/8" NPT to male -3AN fitting, very common: SOLD
Turbo oil drain line, -10 AN stainless steel braided with -10AN female hose ends. Long enough to reach the oil pan right above the oil level sensor: SOLD
Methanol injection pump from Devils Own. About 9 gallons of 50/50 water/meth mix ran through it, 1/4" female NPT fittings: $75 shipped
Autometer 100psi fuel pressure sending unit with connector: $65 shipped
ARP head studs, 234-4110, long and short stud version, used for about 5k miles. Comes with two extra large nuts and washers: SOLD
Please PM me with any questions.
These pics are from KB and show the routing of the cold pipes:
Old Jan 21, 2016 | 02:30 PM
wretched73's Avatar
Where are you located?
Old Jan 21, 2016 | 02:37 PM
Ferocity02's Avatar
CA, central coast
Old Jan 23, 2016 | 09:13 AM
SSnation's Avatar
Pm sent
Old Jan 25, 2016 | 10:49 PM
Ferocity02's Avatar
Bump!
Old Jan 26, 2016 | 12:11 AM
Miguel_in_Denver's Avatar
Pm sent
Old Jan 26, 2016 | 08:36 PM
brandon6.0's Avatar
How did u get that k&n adapter to work like that. I thought they originally bolted to the maf. Did u slip an exhaust pipe into it? I have an old one laying around just like it.
Old Feb 5, 2016 | 11:44 AM
Ferocity02's Avatar
Bump!
Old Feb 16, 2016 | 03:17 PM
Ferocity02's Avatar
Bump! Lowered prices in the first post.
Old Feb 17, 2016 | 09:46 PM
gammey4's Avatar
Will these fit a 2000 Silverado? How much shipped to 37086 for the hot and cold sides?
