lots of stock 4.8,5.3,6.0 parts
Bought a 5.3 from a guy and don’t need a lot of parts he said the motor had a little bit over 100k he also said the reason why he took the motor out was because he thinks the oil pump was going bad but I need the bottom end so here is the list that is for sale if you need better pic txt me for faster response 318-532-6086 parts are very dirty prices are negotiable and prices are w/o shipping + PP fees
Everything free shipping AND PRICES LOWERED ADDED PARTS
Brake Booster hose - SOLD
Stock flywheel - sold
truck intake -SOLD
electric stock T/B - $20 was $30
valley cover -SOLD
valve covers -SOLD
862 heads w/ rockers - HEADS SOLD STILL HAVE ROCKER ARMS SOLD
ac bracket - $15
alternator/power steering bracket -$15 was $20
stock crank pulley/balancer -$20 was $25
stock lifters - SOLD
stock pushrods i have 32 of them total so 2 sets - $10(16) was $15
lifter trays -$20 was $40
i have all 8 coil pack dont know if all are working but will have tested and i have coil brackets - SOLD
stock crank -SOLD
timing cover -SOLD
stock cam(2) - $20 (each) SOLD 1 OTHER IS STILL AVAILABLE
cam sprocket - $10
have a couple of plug wires - $5 each
fuel rail w/ injectors -$45 w/o $20 was $65 w/o $30
engine and trans harness - SOLD
cam position sensor - SOLD
water pump - $25
timing gear w/ chain - $25
i also have a stock converter also - SOLD
Oil pan - SOLD
i have have FMS f13 230/232 .595.585 112 cam as well i would like to trade it or sell for a 224 or a 228 on a 112
got a couple of pistons and rods too if interested
truck intake -SOLD
valley cover -SOLD
valve covers -SOLD
ac bracket - $15
stock crank -SOLD
timing cover -SOLD
cam sprocket - $10
water pump - $25
Oil pan - SOLD
got 7 got pistons and 5 good connecting rods just need to replace rings
piston 3 rod is bad from hitting the rod to knock out of the engine
and piston 8 connecting rod is the same way
