2003 Silverado turbo build..
Old Oct 10, 2017 | 07:56 PM
  #121
ILuvJDM's Avatar
Very clean, just do something with that coolant tank and it'll be mint
Old Oct 19, 2017 | 07:22 PM
  #122
Csnell3732's Avatar
Dual walbro 450's installed, oil changed and new plugs all ready for the dyno this weekend!
Old Oct 21, 2017 | 01:03 PM
  #123
Csnell3732's Avatar
Default Dyno done!
Well finished up tuning the truck on the dyno this morning, went very wel!! 18.5lbs made 892rwhp 786tq, gonna need c02 to up the boost anymore! Not bad for little 5.3 and 76mm
Old Oct 22, 2017 | 03:11 AM
  #124
Boost-freak's Avatar
great numbers congrats .
Old Oct 22, 2017 | 09:01 AM
  #125
2004silvy's Avatar
Awesome numbers man...congrats!! This thing should scream.
Couple questions for you...
Do you have plans for a cage on this beast? Also.. When you installed the walboro 450 did you have to use a hotwire kit as well? Looking at the aem 320 for my truck and hotwire kit seems to be recommend for anything over the 255. What did he stance end up being? 4/6?
Old Oct 22, 2017 | 10:02 AM
  #126
Csnell3732's Avatar
Thanks man... it's a handful!
4/6 drop is what I did. Truck has a little rake to it in the back but I like it. Djm flip only in the rear. Djm upper and lowers up front.
Fuel system I did add a Hotwire kit to it. Had to cut and modify it a little to get it to work correctly. I'm running both pumps on at all times. Running one 450 off stock system like I previously was. Using the hot wire kit to control the second and take all the load from it. Seems to be working well so far!
Cage will be over the winter hopefully!
Old Oct 22, 2017 | 11:37 AM
  #127
Csnell3732's Avatar
Default Final engine bay pics!
Finished up the engine bay installed the air filter assembly finished and installed!
Old Oct 22, 2017 | 01:54 PM
  #128
2004silvy's Avatar
I love how clean that is man. Stock enough looking that most people won't notice that hairdryer under there.
And I'll prob jut order the hotwire kit to be safe and prob the single aem320. I'll only be running a small wet shot with flex fuel injectors. Won't be nearly as fuel demanding as your setup.
Old Nov 23, 2017 | 05:39 PM
  #129
Csnell3732's Avatar
Default Winter upgrades slowly coming in...
Winter is upon us!! Slowly upgrading few things on the truck. Little change up! Sold the lock up circle d that wasn't performing like it should be... went with a 9.5 inch non lock PTC. So trans was removed and added a non lock valve, and overrun clutch valve! Also added a derale deep pan with cooling fins! Also picked up a set of my stiff wall slicks I won in a raffle!
Old Dec 4, 2017 | 08:01 PM
  #130
Csnell3732's Avatar
Default Back in business!
New PTC converter finally made it in!! Truck should be back up and running this week!
