Yet another fog light problem!!
Old Dec 18, 2004 | 02:19 PM
ChevyTrukRacer99's Avatar
Default Yet another fog light problem!!
Ok, guys i got the factory fog light kit, installed it and had the dealership turn them on through the computer for me. They worked for a long time, and now they aren't working, the light on the switch comes on, i checked the fuses, redid the ground and checked the bulbs and i still get nothing. Anyone got any ideas?
Old Dec 18, 2004 | 04:51 PM
KeukaZ71's Avatar
did you have to have your parking lights or headlights on in order to turn on the foglights?
i am trying to think what it might be. is there a relay in the fuse box for them?
Old Dec 19, 2004 | 11:29 AM
Scream's Avatar
MOOBIES Moderator
I have the same problem. The wire end that I put in my fusebox/relay center is loose. It doesn't fit very well at all! Jiggle that wire a little and see if they come back on.
I ended up using zip ties to attach the fog lamp harness to the positive battery cable. Seems to be working so far.
Old Dec 19, 2004 | 12:35 PM
I'll have to checkto see if it's loose. If that doesn't work, I guess i'll just have to hard wire them in...somehow.
Scream, how you did it, does your factory switch still operate the lights?
Old Dec 19, 2004 | 04:05 PM
Scream's Avatar
MOOBIES Moderator
Yeah, I did the factory kit to add the foglights. I got a kit from the dealership that had the wiring harness, airdam, lamps, and switch all together. It was a very simple plug-n-play kinda deal, but the connection just isn't 100% for some reason.
Idryfly5
Sep 2, 2022 08:55 PM
MA$TER_E
Sep 9, 2015 03:14 PM
custm2500
Sep 8, 2015 05:53 PM
markyrgv
Aug 16, 2015 11:50 PM
pupi305
Aug 13, 2015 03:48 PM
