Wilwood's 16" brake package installed (pics inside)
Old May 9, 2006 | 10:18 PM
TexCrew's Avatar
nice..nice
Old May 9, 2006 | 10:42 PM
SlvrSierra4.8's Avatar
What the hell man....those things are freakin massive.....Are 16 inchers really necessary?
Old May 9, 2006 | 11:15 PM
Dave68RT's Avatar
hmmmm next mod..?
Old May 9, 2006 | 11:56 PM
duwem's Avatar
seems like a dumb mod from a performance aspect, if your in it for the bling and run 20's thats great for braking, but what real racer goes to huge *** rims???? 20's are retarded heavy, so why use them in the first place, something that fits in an 18" rim would make more sense, unless you plan on blingin around town on 20s year round (couldnt do that around here with the winter, snow and salt on the roads, and performance tires suck dick in snow) would suck to have to swap out brake parts every fall and spring when switch wheels for the summer/winter
Old May 10, 2006 | 07:02 AM
JimS's Avatar
What suggestions are out there for 18" wheels? I"d be strongly interested in getting $$ quotes for systems to fit with 18" wheels. Rotors, calipers and SS hoses.
Old May 10, 2006 | 08:35 AM
TG02Z71's Avatar
How about an upgrade for stock rims, allot more peple have stock or stock size wheels, even though 20's look cooler most don't have them.
The way I look at it, if if don't make me go faster....or stop faster its second on my list of mods.
Old May 10, 2006 | 08:43 AM
8ALTNG's Avatar
Its faster thans yours
Old May 10, 2006 | 09:16 AM
Those would be great on a tow rig.
Old May 10, 2006 | 09:52 AM
Scream's Avatar
MOOBIES Moderator
First off, looking great Tom!
Originally Posted by TG02Z71
How about an upgrade for stock rims...
https://www.performancetrucks.net/fo...d.php?t=364314
I run stock wheels at the track, so I went with the Baer drilled/slotted DecelaRotors from TByrne. Just waiting on the rear set that Baer mispackaged and we'll have new brakes at all 4 corners. Definitely a huge improvement over stock!
That's one of the main reason to upgrade your brakes when running big wheels. The increased rotating mass definitely requires better brakes to get things stopped.
I'm a real racer, and I have a set of 20's for show, and a set of stock 16's for go. I was able to upgrade my brakes and still keep the use of the 16's at the track. See my post above.
Old May 10, 2006 | 12:07 PM
tbyrne's Avatar
looks very nice. How is brake fade on repeated hard stops and can you get the rotors slotted only?
I haven't hammered them to much but brake fade wasn't bad the few times that I made repeated hard stops. Really noticed the difference when someone didn't see me and backed out of their driveway while I was doing about 40. Hammered the brakes and thought "wow, not bad!". The standard rotors are slot only.
Of course!
I'm running a Westers race tune for the DuraMax along with some bolt-ons and a built transmission but no race truck here. Mostly bling -
It rides on 22s in the summer and 20s when the snow starts to fly. I use it as a tow vehicle and daily driver in the winter. What you say is true through, BIG wheels aren't fast. I'll give up a little power for looks once in awhile.
The Baer Eradispeed packages will work with 18" wheels. Most kits are available for around $1000. They come with red powdercoated calipers so everything looks pretty good.
Scream has that covered. Baer's Decela rotors work within the stock wheels. Powerslot also has stock replacement rotors. Alot of people go with those and Hawk pads. Some also upgrade the lines. Stopping distances get shorter and the pedal feels better.
