Will 22's fit on a lowered 02 silverado?
Old Apr 30, 2003 | 08:09 AM
StreetSweepa's Avatar
Default Will 22's fit on a lowered 02 silverado?
Just wondering if they will fit....i wanted to borrow my friend's 22's for an upcoming car show.
Old Apr 30, 2003 | 08:44 AM
Scream's Avatar
MOOBIES Moderator
Default Re: Will 22's fit on a lowered 02 silverado?
Which tires? How wide are the rims? What's the offset?
If they are the lower profile 22" tires, they should work fine. The larger tires or a wider rim with the incorrect backspacing could cause them to rub a bit.
I would try bolting them on, then checking for clearances--especially when turning. Do all of this before you drive on them...turn the wheel lock-to-lock and have someone check all of the clearances for you.
I think that most 22" combos should fit fairly easily on a 3/5, but I would test everything out thoroughly before you ride on them!
Old Apr 30, 2003 | 09:05 PM
Worst comes to worst and they don't fit,bolt them on when you get there and take some pictures of them so we can see.I've never seen a lowered new body on 22's
Old May 1, 2003 | 07:52 AM
Scream's Avatar
MOOBIES Moderator
DJM 4/6 drop on 22" Boyds...
Old May 1, 2003 | 08:31 AM
Scream's Avatar
MOOBIES Moderator
More pics HERE
Old May 1, 2003 | 08:54 PM
Feed's Avatar
photoshopped. look at the rollpan and where the concrete meets the stones. if a 4/6 were that low i'd be tucking all the rubber on my 275/35's
Old May 2, 2003 | 01:10 AM
Ryan23silverado's Avatar
That is photo shopped. Look at the ground underneith the roll pan. They didn't get that part of the picture matched too well. I have a 4/6 drop with 20s. Some 22s would fit. I don't think it would be good for daily driving, but they would fit.
That guy is from AZ, but I don't know who he is and have never seen the truck around at shows. I go to all of the big truck shows and have never seen him. Who knows??? It is a nice show truck though - I like the paint. (on the outside. the inside was kind of overkill)
cams 98 silverado
Jul 31, 2015 07:36 AM
signguy62
Jul 27, 2015 03:42 PM
Ammadien
Jul 22, 2015 08:50 PM
maxspeed05V
Jul 19, 2015 07:08 PM
Mark_k
Jul 9, 2015 12:37 AM
