Who's rocking some 315 radials?
Old Feb 16, 2018 | 09:32 AM
Vortec350ss's Avatar
Default Who's rocking some 315 radials?
Let's see em!
Post your suspension set up as well as wheel specs (width and offset)
My truck is lowered 4/6 and I would like to get an idea of what I can fit.
EDIT - SEE POST 15 FOR UPDATED PICS OF MY TRUCK ON 315's
Old Feb 16, 2018 | 03:06 PM
AMS13's Avatar
Vortec, your truck looks great. What size tires do you have?
Old Feb 19, 2018 | 09:11 AM
MrHorsepowerLSx's Avatar
11 Second Club
Not a 315, but close
325-50-15’s
15x10 6.5 bs
2/5 drop
Attached Thumbnails Who's rocking some 315 radials?-4f0db96a-f87d-4ed2-8a8f-261a5c2c8c77.jpeg   Who's rocking some 315 radials?-868f9ca6-3142-421e-819f-a7a199f3c693.jpeg   Who's rocking some 315 radials?-f1cca794-6e4f-44c9-ae5a-59f875044c26.png
Old Feb 21, 2018 | 07:44 AM
ss4chad's Avatar
12 Second Club
I don't have a pic but I run a 295/35 20 in back. Truck is lowered 3" / 4" wheels are Centerlines in all four corners with the back wheels widened to 10".
I have room for 315 but the extra cost and weight makes me stick to the 295
Chad
Old Feb 21, 2018 | 11:21 AM
They are M&H 325/45r17's out back (28") that dont really measure to a true 325. The fronts are 235/65r17's I believe.
I was looking for members running 315/60r15 drag tires.
Old Feb 21, 2018 | 01:40 PM
BigKID's Avatar
What width wheel were you planning to use? 315/60/15 are going to be a tight fit if you're still running leaf springs and stock fenders.
295/65/15 on a 15x10. The fender lips are rolled and iirc tire is about 3/4" from the leaf spring at the closest point.
Old Feb 21, 2018 | 02:15 PM
BigKID's Avatar
I knew someone on here was running 315 on a 15x10 racestar with a 4/6...
https://www.performancetrucks.net/fo...5/#post5340403
Old Mar 2, 2018 | 11:13 AM
Reckless's Avatar
Still moddin'
So what is the widest tire with no shocks or leafs outside the rail (4-link) and stock fenders on a GMT800? Anyone know?
Old Mar 29, 2018 | 10:13 AM
I have 315 pro's on mine and I am going to need to make a little space.
Check out this from Foose... its almost exactly what I have going on.
https://www.performancetrucks.net/fo...ctures-544549/
Old Mar 29, 2018 | 11:47 AM
blown02408's Avatar
02 w/ lowest mileage 2800
16.5” wide if you tub it
