wheels and tires, make the truck move.
Old Feb 16, 2005 | 04:56 AM
onyx's Avatar
14 Second Truck Club
Default wheels and tires, make the truck move.
ok... lets see.. a 2/4 drop... with 20x8.5 w/ 245/40ZR-20 tires and 20x10 w/ 295/40ZR-20. what backspacing?.. i wont be going with bags. this combo work?
Old Feb 16, 2005 | 07:14 AM
SnakeOiler's Avatar
Go with 6" up front and at least 7" in the rear - you will stay tucked. You can go 7.5" in the rear if you want to truly clear that fender lip - in case you to come down more.
My homework is done already for this. I'm going with the same size wheels, 6" front bs, 7" rear bs - except I'm going with 265/50 and 295/45 - I wanted a tad taller tire for the higher load rating.
It may be what you are going after, but you do realize that your front tire size is a smaller diameter than your rear tire size?
Old Feb 16, 2005 | 07:21 AM
Scream's Avatar
MOOBIES Moderator
Pretty similar setup as Smokinrice, but he has a 4/6. Ever thought about slamming it?
Wheels/Tires
Intro Twisted Vista II’s w/Kuhmo Tires
20x8.5(F) 255/35-20
20x10(R) 295/40-20
http://acrophobia.net/chrismfl.html
Old Feb 16, 2005 | 07:26 AM
onyx's Avatar
it was what i was going after. easier for turns.
Old Feb 16, 2005 | 07:29 AM
onyx's Avatar
yup... but changed my mind... a 5.5 backspace would keep me in the contention for a slam in the future though.. correct?
bonspeed intense 6's and BFG KDW's all for 3050. brand new.
Old Feb 16, 2005 | 08:15 AM
Scream's Avatar
MOOBIES Moderator
Mine are 20X8.5 at all four corners w/ 6" b.s. 5.5" might not cut it. Rears would need to be about a 7" b.s. I would think.
Old Feb 16, 2005 | 08:23 AM
onyx's Avatar
ok cool... i'll go with 6 up front , and research for the rear some more.
Old Feb 16, 2005 | 08:26 AM
Scream's Avatar
MOOBIES Moderator
Check w/ Bryan (Introwheels) as those Intros used to be his. I'm sure that he could help you w/ the backspacing question.
Old Feb 16, 2005 | 12:36 PM
SnakeOiler's Avatar
you'll need 7.5" (with the 10" wide) for the rear backspace if you want to drop 6" and clear. 7" bs you will have to roll the lip. But for a 4" drop, either should to fine.
Old Feb 17, 2005 | 05:57 AM
onyx's Avatar
im not going to go any lower, except maybe another 2" in the back. with this tire sidewall size, you guys dont think there would be too much gap do ya?
