whats the fix for lite scratches on headlights?
Old Aug 20, 2009 | 09:23 AM
andrew383's Avatar
traveling mod
Default whats the fix for lite scratches on headlights?
like a dumbass i used a dish sponge to clean somebugs off a set of headlight housings i have and it now has a "haze" on it.
I know there those cleaning kits for dull lights but i dont want to waste the $$ if its not going to fix it.
So whats the best thing to do/use to buff it back out??
Old Aug 20, 2009 | 01:19 PM
Wonderer876's Avatar
i know to pull yellow out i use mothers paste mag wheel polish, it clears them up i dunno how well it will work for scratched thou, you could try its basically a fine polish
Old Aug 20, 2009 | 01:30 PM
RandomHero's Avatar
Hit it with some Poorboys SSR1. It will take a while by hand but it will look great when you're done.
Old Aug 21, 2009 | 09:14 AM
1quickRST's Avatar
PlastiX from Meguiars works awesome! I use it all the time! Should make them shine like new!
Old Aug 21, 2009 | 10:28 AM
garcia's Avatar
^^ how do you apply plastiX.I bought it and could not get it to work
Old Aug 21, 2009 | 10:31 AM
viciousknid's Avatar
Where's the Beef?
One of mine looks like it's covered in some yellow sap that you can't scrape off. I'm sure it's recoverable with some wet sand and some plastix but never bothered to try.
Old Aug 21, 2009 | 12:36 PM
D_reks{5.3}'s Avatar
Yep takes some wet sanding and some polishing.
Kits you buy at the stores just come with "spray lubricant" and Compound with some lil sand paper squares.. I would just try some 2000 grit wet sanding, and just polish it off and see if it helps..
Old Aug 21, 2009 | 04:45 PM
andrew383's Avatar
traveling mod
thanks for the ideas guys
Old Aug 22, 2009 | 09:32 PM
1quickRST's Avatar
Just put it on a terry cloth towel and spread it over the areas that you want to polish and use medium pressure and rub in a circular motion....If you buy the head light restoration kit you get a polishing wheel for the end of a drill. That works really good!
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
chvy=power
Sep 28, 2015 10:32 AM
