whats the best
Old Dec 27, 2007 | 05:50 PM
andrew383's Avatar
traveling mod
Default whats the best
way to remove side moldings from my 07 classic???
Old Dec 27, 2007 | 06:13 PM
onebad03's Avatar
i use a putty knife covered in masking tape and a hairdryer/heat gun to heat up the edge a little and get the putty knife started enough to get your fingers under it and the slowly pull it off while heating it with the hair dryer/heat gun. and if your lucky enough to get all the tape off with it,which happed very rairly if at all, the best thing to use for removing the tape would be an eraser wheel from your local paint supply store or i have heard NAPA sells them too.
Old Dec 27, 2007 | 06:14 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Teflon spatula and WD40.......don't let the wife see you.
Old Dec 27, 2007 | 06:45 PM
onebad03's Avatar
i have heard about the wd40 but it didnt work for me. are you supposed to soak it and let the wd40 do its thing or spray and scrub?
Old Dec 27, 2007 | 06:56 PM
chuckie311's Avatar
GOOOO Gone works the best
Old Dec 27, 2007 | 07:48 PM
Mangled03gmc's Avatar
Baltimore Whore
Use a chain saw it works well but **** the paint up a bit, the sheet metal.
Wd40 or goo gone works pretty good, once ya get it started it should come off pretty easy.
John
Old Dec 27, 2007 | 08:55 PM
GTOsRamairSilverado's Avatar
i think thats what works the best. i tried the WD40 but didnt have any luck with it.
Old Dec 27, 2007 | 09:30 PM
riddick1224's Avatar
Go to the closest Chevy dealership and ask the body shop to do it. That is what I did and it cost me about $40. I had the moldings on the doors. The LS emblems on the pillars and the "Chevorlet" and "Silverado" on the tailgate taken off too. It looks great.
Old Dec 27, 2007 | 09:43 PM
00Silv4.8's Avatar
autozone list: plastic putty knife and goo gone. Be a man and rip that **** off by hand too. Its real easy. then get the big stuff off with plastic putty knife then rag and goo gone for the residue. then hit the car wash
Old Dec 28, 2007 | 12:03 AM
slownlow4.8's Avatar
the best way is with a plastic putty knife and an Eraser wheel
