what to torque bogart wheels to??
Old Jun 21, 2014 | 01:46 PM
2doorfury's Avatar
Default what to torque bogart wheels to??
Last week I pulled into a local cruise in and had a guy come up to me and hand me 2 lugnuts. He said he seen it come off my truck as I drove by. I parked, walked around the truck and noticed there were 4 lugnuts missing, 1 was loose and 1 was tight. I torqued them at 75 ft. Lbs. and only put about 30 miles on them basically from my house, to the cruise in were I found them already flinging off. I found that f body guys were torquing them to thsoe specs and thought it would also be ideal for a 6 lug truck. So what's the real torque. Obviously mine is wrong and it could of been catastrophic.
Old Jun 21, 2014 | 02:00 PM
GMCtrk's Avatar
140 lb/ft is GM spec. I torque mine to 120.
Old Jun 21, 2014 | 09:12 PM
2doorfury's Avatar
Damn. So I was a little ways off. I'll have to torque them around 120 ft. Lbs then
Old Jun 21, 2014 | 09:53 PM
FFDP's Avatar
Agreed, in our shop we do anything that is a half ton to 125 ft lbs.
But really if all were done at 100ft lbs they would be okay, an even torque is better than under torqued.
Old Jul 12, 2014 | 10:08 PM
5speedsilverado's Avatar
i always torque the wheels to factory specs aftermarket or not. 140 is where gm thinks it needs to be so i put them there.
Old Jul 12, 2014 | 11:04 PM
custm2500's Avatar
Ph.D. in HUBRIS
If you are going to torque the wheels to or around factory spec, make sure you re-torque the wheels 30-50 miles after. Factory spec is often too loose because the studs have been over torqued in the past. Therefore they are stretched/weekened and aren't going to hold 140 ft. lbs. as well as they should.
Old Jul 12, 2014 | 11:17 PM
Chevy_King1500's Avatar
impact does the job
chopperloco
Jul 10, 2016 10:45 PM
zachman078
Sep 21, 2015 04:36 PM
zaathur151
Jul 6, 2015 10:57 PM
