wet sanding didnt go so well
Old Jan 22, 2007 | 12:15 AM
smooth_addictions's Avatar
yeah i thought that it would work. but no go. im slowly getting the scratches out little by little. tommorow is a new day. hopefully with the right tools. lol live and learn i guess!
Old Jan 22, 2007 | 07:22 AM
Frito Bandito's Avatar
Why did you wetsand your truck? What are you trying to buff the wetsanding marks out with?
Please dont buy a rotary yet, do some research first so you dont make the problem worse. I reccoment you do some reading on porter cable 7424 and 7336 dual action polishers instead of a rotary. Start here . You may also want to do some reading on autopia.org.
With a PC 7424/7336, some Menzerna Intensive Polish, a flexible backing plate, and an 6" orange lake country CCS pad you will be able to repair the damage.
Old Jan 22, 2007 | 07:46 AM
silverdenali22's Avatar
Yes you need a high speed buffer and 3M extra rough cut 3 and 3m perfect 3 glaze. Turn the buffer on speed 3 or 4 and keep moving don't stay in one spot or you will burn the paint.
Old Jan 22, 2007 | 12:56 PM
thanks for the great advice.
Old Jan 22, 2007 | 01:34 PM
So what are you going to do? Let us know how it turns out.
Old Jan 22, 2007 | 01:39 PM
BlackGMC's Avatar
Resident Retard
Did you just use rubbing compound after the wet sanding? Your supposed to use a compound, then a swirl remover.
Old Jan 22, 2007 | 02:51 PM
NegraRCSB2X4auto's Avatar
Man just take it to a detail shop or a body shop and let them buff it off.
Old Jan 22, 2007 | 04:27 PM
i refuse to. lol i have too much time into it to give up now. im gonna do some research then go from there.
Old Jan 22, 2007 | 04:29 PM
yeah i used a rubbing compound. didnt try the swirl remover though. like i said a little bit of research and some new **** i should be good.
Old Jan 22, 2007 | 04:52 PM
BlackGMC's Avatar
Resident Retard
Swirl remover, removes the swirls. I think if you tried some it would remove the marks. I have just a regular buffer used to wax my vehicles and that is what I used after wet sanding on a couple of projects. It just take a little longer.
If you want to get a high speed buffer but don't want to pay top dollar, go check out some Pawn shops, that is where I got mine for a fraction of the cost.
