Wanting to smoke turn signals/tail lights, could use some advice.
Old Oct 18, 2009 | 07:57 PM
Default Wanting to smoke turn signals/tail lights, could use some advice.
I've read different threads around a few sites and have seen where some people have used window tint on their lights (I would prefer not to do it that way), and some have painted them with different products. Does anyone have any specific products they have used for this that works well? I'm not wanting them to look completely black like some I have seen before.
I'm wanting to get something going on this while I'm painting my grill and hood to go on my s-10. I'm fixing it where a guy backed into it the day I bought it. It should look kind of like the truck in this thread, only with stock wheels: https://www.performancetrucks.net/fo...d.php?t=435488
Forgive me if there is already a thread out there on this, I have dial up and have been looking for about 2 1/2 hours. Thanks in advance for any help I can get on this.
Old Oct 18, 2009 | 08:00 PM
TouchOfEvil04's Avatar
I did mine on my 04ecsb i believe i used VHT Night Shades. Came out great, real easy to do.
Old Oct 18, 2009 | 08:05 PM
Did you prep it like you would to paint? Where did you buy it at?
Old Oct 18, 2009 | 08:21 PM
I lightly sanded it with some 400 grit paper, then washed it with some dawn to remove any grease. Dried it up real good and the sprayed it.
I ordered it online. Just do a search in your toolbar or on google for VHT Night Shades it's on amazon and many other sites. You can clear over it as well if you wish. I did not and 4 years later still good.
Old Oct 18, 2009 | 08:38 PM
BLK WDO's Avatar
your nightshades will turn out good if you clear over them but IMO they turn out dark.
if you have a paint gun and some black paint you can tone it out....like so
scuff the lamp of your choice with fine grit paper until the shinny is gone.
whipe clean
mix some clear with black paint. sprayin light coats. spray until desired darkness is reached and then spray two coats of clear. wet sand then polish.
i did that to my tail lights and its not too dark but not to light. (2 coats)
Old Oct 18, 2009 | 08:49 PM
03chevyroyce's Avatar
i used nightshade when i did mine
its available at some O'riellys ive seen
Old Oct 18, 2009 | 08:58 PM
2000chevysilverado's Avatar
Ive used nite shade good stuff just wet sand when done spraying and use plastix shine looks good when done
Old Oct 18, 2009 | 09:35 PM
Ender06's Avatar
I used Night Shades, works great, but VERY DARK, I have LED's in the lights now
Old Oct 18, 2009 | 10:44 PM
firehawk#682's Avatar
Ive used niteshades and Testors model Spray tint P/N (TES2949) and i like Testors better. It flows out way better then the niteshades and is not as dark. Just google the part number above and you will find it. The pictures dont do it justice it changes with the light as you can tell.
Old Oct 18, 2009 | 10:47 PM
Perezownzu's Avatar
of you use nightshades dont use to many coats
