Tire size question...all you tire experts!
Old Jul 17, 2008 | 01:01 PM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Default Tire size question...all you tire experts!
I am currently running 285/50/20’s. What will going to 275/65/20 do? Will it be much different in size, i.e. if I have no rubbing issues now will I with these?
Old Jul 17, 2008 | 01:04 PM
MeanZ71's Avatar
ya you'll rub your going from a 31" tire to a 34" tire
I'm just joking bro, here's a metric converter to actual height and width http://www.4x4sites.com/techreports/...ator/index.asp
Old Jul 17, 2008 | 01:09 PM
10RamSport's Avatar
Thanks for making me sweat man!
I used this calculator and the specs don't seem that far off.
http://www.discounttiredirect.com/di...foTireMath.jsp
Old Jul 17, 2008 | 01:15 PM
MeanZ71's Avatar
I run the 285/50 and its a great size IMO, they're wider and just a hair shorter than the 275/55s and always cheaper. good luck
Old Jul 20, 2008 | 10:27 AM
2kewl's Avatar
Slap 'em on and see if you do or don't. If yes then just trim the plastic skirt in the wheel well. I stuffed 35"x13.5" Mickey T's into my avalanche (I have a 6" lift though so height may be an issue for you)
Old Jul 21, 2008 | 06:27 PM
VroomVroom's Avatar
Are you sure 275/65 is the correct size, or could that be a typo and you meant 275/55?
If it is a 65-series sidewall, you will undoubtedly have fitment issues. Most folks I know have gone with at least a 2" lift to run 33" tires. Since these are a bit over 34", you'd need to go up, I'm guessing by at least 4".
If it's the 55...no sweat. It's actually the same spec as "stock" and just a wee bit taller than your 285/50's.
Old Jul 21, 2008 | 06:41 PM
10RamSport's Avatar
Yeah, I gave up on the tires for now. Thanks for all the help guys!
gbbmk
Sep 29, 2015 10:19 AM
Lamartian92
Sep 10, 2015 09:27 PM
southernsmoker
Aug 31, 2015 03:09 PM
Lamartian92
Aug 21, 2015 01:43 PM
luisalmighty09
Aug 20, 2015 11:35 PM
