Tire Size help
Old Nov 15, 2005 | 08:13 PM
Default Tire Size help
I am wanting a set of 275's for my truck, but I want the same height as the 245s on it now. Any help on which size will work? It's a 17" rim by the way
Old Nov 15, 2005 | 08:25 PM
StrokerAce03's Avatar
Are the tires you have now 245/70's? If so then a 275/60 17 is about the closest to the stock size as you're gonna find. Its about 29.9 in. vs. a little over 30 in.
Old Nov 16, 2005 | 12:08 PM
NBred94's Avatar
285/60/17's (30.46 in)are almost spot-on with the height of the stock 245/70/17's (30.50 in.) on my truck. 275/60/17's are 29.99" tall, so you would only give up half an inch in height.
From reading on tire-rack or some other such site, the minimum width for 285's is 7.5", which is the width of the standard '05 chrome steel Sierra (and I assume Silverado as well) wheels. That's probably what I'll end up getting when the stockers wear out.
EDIT: Here's a LINK
Old Nov 16, 2005 | 02:59 PM
Gran Patron's Avatar
The 275's will just be a little wider tire!
gbbmk
Sep 29, 2015 10:19 AM
Lamartian92
Sep 10, 2015 09:27 PM
southernsmoker
Aug 31, 2015 03:09 PM
Lamartian92
Aug 21, 2015 01:43 PM
luisalmighty09
Aug 20, 2015 11:35 PM
