Steel hoods with heat extractors?
Old Mar 6, 2007 | 11:04 AM
thunder550's Avatar
High on diesel fumes
Default Steel hoods with heat extractors?
Anyone make a good stock-looking steel hood with functional heat extractors? Need something to get the turbo heat out from the engine bay. I don't want fiberglass or composite, and I don't want a scoop on the front. A little bit of a cowl shape would be ok, but nothing drastic. What's out there?
Old Mar 6, 2007 | 11:51 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
The Goodmarks and the Reflexxions are functional, and popular.
Old Mar 6, 2007 | 11:59 AM
thunder550's Avatar
I looked at both but don't see any with heat extractors......
Old Mar 6, 2007 | 12:07 PM
beastmode's Avatar
Import Moderator
well goodmark makes em, but i think they only have em for 88-98
Old Mar 6, 2007 | 03:44 PM
TurboJohn6's Avatar
Don't mean to sound stupid but what exactly do you mean by heat extractor? Are you just looking for a functional type of hood with openings on the underside that go to the outside?
I have a reflexxion cowl hood and it has an opening on the underside of it that will vent the hot air through the cowl. I would recommend it to you for what you are looking for.
Old Mar 6, 2007 | 03:52 PM
thunder550's Avatar
Yeah I was thinking actual openings through the hood, but I read another thread where some cowl hoods are for induction and some are for heat extraction, so it sounds like just a normal cowl hood designed for extraction rather than induction would be the way to go.
Old Mar 6, 2007 | 04:37 PM
RERICK's Avatar
I think cowl hoods were originally designed as an air intake system. To take advantage of the low pressure area at the base of the windshield . The only time you would see any heat extraction would at a stop or really slow speed. Some louvers of some type would probably be more affective .
Ron
Old Mar 6, 2007 | 09:14 PM
HDMLNIUM's Avatar
I have the Reflexions steel cowl on my truck and it is functional. But it is for intake air coming in and not really designed to be for heat extracting. But none the less it is still a geat looking hood.. lol
Bill
Old Mar 6, 2007 | 10:48 PM
TurboJohn6's Avatar
Ron
You are 110% right Ron. I believe GM even advertised the cowl hood with that exact same wording to describe how it worked. There is one thing different though. There is not an air cleaner sealed to the underside of the hood at the opening. Without the opening being blocked, the hot air should vent throught the cowl while stopped or at a slow speed (like you said). At speed, air will enter through the front of the truck and push out wherever it can. There should be no reason why the cowl would not help vent the hot pressurized air from underneath the hood. I know the cowl hood was not originally designed to be used in this particular manner but it should do the trick.
Old Mar 6, 2007 | 10:56 PM
trever1t's Avatar
This is what I was thinking when I put mine on. My underhood temps usually are low too.
