Spray in bedliners???
Old Sep 10, 2004 | 10:22 PM
BlOWNSS's Avatar
line x , get it or you will kick yourself later.
Old Sep 11, 2004 | 06:28 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by BADMOFO
Who/where did you get it done for under $300?
i was at the BIG M spring bash(churchville) and they were doing a special on them.plus got 2 beer coolys. today and tommorow they will prolly be there. under the rail is the sides, bed but just not on the tops of the bed rail
Old Sep 11, 2004 | 06:32 PM
quicksilverado's Avatar
Line x here.
Old Sep 19, 2004 | 02:38 AM
fordeader's Avatar
i recently had rhino sprayed....i had them spray over the rails too..it ran me $375. it looks great.....for as fading in the future, dont know yet.....
Old Sep 19, 2004 | 12:48 PM
Speedextreme's Avatar
I am going to get the Line-X in my truck here soon. But I also wanted to mention that I read in a Magazine, that some of you might saw. That they were rebuilding a boat trailer and when the had the new wood that holds the boat on the trailer (the "bunks") They had those pieces of wood Line-X'd, and then carpeted over them. I just so happen to have a boat and a trailer that desperately needs rebuild and I am going to have that done to the wood at the same time of my bed and hopefully save me a little bit of money. They say it seals the wood like you wouldn't believe! NO MORE ROT! I love it!
Just thought you might like to know!
Old Sep 20, 2004 | 03:52 PM
smooth sierra's Avatar
take it from a fellow boater that has been there/done that. Go to local hardware store, I chose Lowes and buy a gallon of fiberglass resin. no need for the glass just the resin. Buy some cheap brushes that will be worthless when done. Then cut your new bunks and brush on the resin. Let it dry 24 hours and carpet. It will last forever and is very inexpensive. Just be sure to mix the resin/hardener in small amounts as it can and will start to cure fairly quick.
I know resin is made to bond to wood and definitely designed for a marine environment. it also makes a smooth finish. I would think the rough finish of a bedliner would cause problems with adhesion with the glue. I would think friction caused by the boat moving on the trailer would eventually wear away the carpet from the inside out
kainzien
Nov 10, 2023 11:37 AM
twake_410
Apr 14, 2016 09:58 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
sprayed99
Sep 21, 2015 04:47 PM
sprayed99
Sep 14, 2015 12:36 PM
