Smoking the tail lights
Old Apr 8, 2008 | 09:19 AM
Cuerva's Avatar
11 Second Truck Club
Local painters are doing them left and right around here for 30-45 a set including 3rd brake light. Some use a mix of auto paint with clear and others just spray some paint to desired tint and then clearcoat them. Mine were sprayed then clear coated, this gets better results and come out very shiny.
Old Apr 8, 2008 | 09:40 AM
rxsteven's Avatar
Thanks for the link!! CAnt get much better than that Im going to order some today ill post some pic as soon as I get them done.
Old Apr 8, 2008 | 11:56 AM
12 Second Club
How many people have done this using the VHT Niteshades method?? Seems easy on a smooth lens like the F-Bodies have, bud wondering how well it looks on the Yukon/Tahoe tailights. Any pics out there???
Old Apr 8, 2008 | 12:12 PM
Blitanicle99's Avatar
Definately do the Nite Shade method. Turns out much better. The trick is the sanding beforehand.
Be careful this product will run very easy and takes quite a bit of time to dry for just one coat. Take your time and it will turn out fine.
Old Apr 8, 2008 | 02:18 PM
NegraRCSB2X4auto's Avatar
vht sucks it peals off. i've tried.
Old Apr 8, 2008 | 02:23 PM
95 bright teal's Avatar
if you want a full write up there is a new post weekly about niteshades on ls1tech. i would do a search there, lots of info
Old Apr 8, 2008 | 04:17 PM
Black-Jacket's Avatar
Originally Posted by Derek @ EDO
Im going to use VHT Niteshades.
Summit sells it.
Suppose to work pretty good!
garbage, leaves the taillights flat and milky looking
few drop of black mixed with clear and spray
Old Apr 8, 2008 | 04:21 PM
Red03SilSS's Avatar
Ive done prob 20 sets in the last 2 months around the waco area. I spray them with PPG paint. use black base coat and go to the desired darkness then clear over it. I even did one trucks green and put blue pearl in another one. Sand and buff them and they are perfect. Make sure you ALWAYS spray a plastic adhession promoter on it first so in a few years it doesnt start to peel.
Old Apr 9, 2008 | 03:39 AM
12 Second Club
...and if you don't have a spray gun???? lol
Old Apr 9, 2008 | 04:17 AM
LowBlack99's Avatar
Pick up a cheap one from the parts store, you dont have to have a $500 gun to get good results on small parts. Make sure it's a gravity feed with a 1.3-1.5 tip and if you can get a HVLP they are even better.
