Slammed 4x4s (Convince Me)
Old Jun 23, 2008 | 01:57 PM
Blitanicle99's Avatar
Default Slammed 4x4s (Convince Me)
I wanna drop my 01 Ext Cab Z71 pretty bad. I would be removing the factory block, uncranking my cranked torsion bars... and throwing a shackle in the rear.
My own big concerns are, A. Ride Quality...
B. I will be running stock rims and tires (31.3s) for awhile. Fitment problems?
Oh and are different shackles better quality and/or have a different drop?
Pictures would be awesome too!
Old Jun 23, 2008 | 02:02 PM
Dominion's Avatar
just do it.
Old Jun 23, 2008 | 02:44 PM
gao8302's Avatar
I would get the spindles. I have them and they keep the ride like stock. You just have to run a min. 17" rim. Just doing the torsion bars can make the truck ride a little rough. I would get you some pics but my camera is broke. Just do it and be done with it.
Old Jun 23, 2008 | 02:48 PM
Oh and how many full turns should I be doing so I come from a fully cranked to a fully lowered stance? I just did 10 turns per side (posting from the laptop in the garage)and its exactly an inch lower. I want it lower.
Post up ASAP! lol
Old Jun 23, 2008 | 02:59 PM
gao8302's Avatar
Once you play with the torsion bar you should have it aligned. Get the spindles and you will have about 3" in the front.
Old Jun 23, 2008 | 03:05 PM
I thought you couldnt do spindles with 4wd because of the CV?
And apparently according to my buddy you can remove the bolts completely and it wont hurt it. I was just gonna take it allll the way down with the torsions for now, and do spindles later if possible. I just want a different look and its a spur of the moment thing, Im taking wenesday off to pull my blocks and put the diff U bolts in.
Old Jun 23, 2008 | 03:10 PM
gao8302's Avatar
My truck is a 4wd and i have the spindles. Trever1t has them too. Check his truck out. They are made for our trucks.
Old Jun 23, 2008 | 03:16 PM
******* SOB!!!!!!!!!!
F'ing torsion bolt broke. I was 2 full turns away from level and 2 inches lower. AHHHHH!!!!!
Old Jun 23, 2008 | 03:21 PM
gao8302's Avatar
That will be fun to get out. I would remove the torsion key to get it out. If you dont you will have alot of stored energy form the suspension.
Old Jun 23, 2008 | 03:32 PM
Its got about an 1/8 inch gap before it is completely bottomed out. I just took it out for a drive, it rode much better than its ever has. Im debating drilling it out... Bad idea?
