Scratches!!!!
Old Feb 8, 2008 | 05:12 PM
xchevyx24's Avatar
Default Scratches!!!!
OK, Whats the best way to remove scratches on my black truck? I got a couple from a damn bush and one pretty deep one from some dumbass with a knife in his pocket that decided to walk by my truck.
Old Feb 8, 2008 | 05:26 PM
Mangled03gmc's Avatar
Baltimore Whore
Clay bar it then hit it with a buffer and foam pad with a super light cutting compound, then a good coat of wax.. If it is too bad you may have to hit it with a milder cut compound and a wool pad...
John
Old Feb 8, 2008 | 08:18 PM
onebad03's Avatar
yeah do what mangled said but if its too bad you may want to lightly wetsand with 1500or2500 then some 3000 beforehand.
Old Feb 8, 2008 | 11:04 PM
rpav's Avatar
f'in victorville *****!! no appreciation
Old Feb 9, 2008 | 01:27 AM
xchevyx24's Avatar
There is nothing eles to do here so we go offroading!
Old Feb 10, 2008 | 12:30 AM
fake_usa's Avatar
If your doing it by hand, Meguiar's Scratch X is by far the best !!
You can even do a little wet sanding them polish it out with the Scratch X.
Old Feb 10, 2008 | 12:45 AM
RandomHero's Avatar
Sorry,but not it's not. I'm not sure if you are the same guy preaching scratch x from the other thread, but Scratch X is just a filler. It won't take out scratches. I speak from personal experience as well as from other's experience. I have a tube of it that's been sitting unused virtually full for the past 2 years. It gets put behind my Poorboys polishes and other products that actually work.
Even if you're doing it by hand you'll want to go with an abrasive polish. The deeper the scratch the more abrasive the polish will need to be. FWIW, almost everything you can buy at an autoparts store won't work
Old Feb 12, 2008 | 04:50 PM
sercastiK's Avatar
grab either pro polish or body shop compound from chemical guys.
chemicalguys.com
it will blow the ***** off any of that meguiars, they are in So Cal also.
If you call them talk to Paul tell them Larry from San Diego sent you
SlvrSierra4.8
Oct 1, 2015 09:42 PM
chvy=power
Sep 28, 2015 10:32 AM
Closer_2001
Sep 16, 2015 11:46 AM
the owl
Sep 4, 2015 04:09 PM
fiatdale
Not Manufacturer Specific Parts
Aug 26, 2015 07:36 AM
